Author Topic: Now thats blown it!  (Read 1685 times)
omegod
  • liverpool
    • 2017 Seat Ateca
Now thats blown it!
« on: 07 November 2010, 11:43:50 »
Reconnected my battery after running it down with my starting problems, went to crank it and something has blown( big bang and a puff of smoke) in the engine bay:
Fault codes 53 Fuel pump relay voltage low( already had this with the starting problems)
94 Hall sensor voltage high
73 mass air voltage low
57 Idle control valve voltage low
Where to start, are these on the same fuse or summat?
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Now thats blown it!
« Reply #1 on: 07 November 2010, 12:44:26 »
Don't bother with any replys as it's going in to a spark tomorrow and I'm off the pub to drown my sorrows! :) proper had enough of it and will go and buy a pug 306 as I heard they have more  reliable electrics  ;D
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #2 on: 07 November 2010, 12:50:26 »
cant fault you on that. wouldnt be the ecu thats blown up would it? :-?
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 07 November 2010, 12:55:46 »
I guess so Baron, may have been the initial fault causing the non start and now it's blew completely. Going to play dim in the morning and get the AA to tow it to a spark.
« Reply #4 on: 07 November 2010, 13:12:35 »
I know you don`t want replys :D but it sounds like one of the fusible links has blown in the small box clipped to the relay box
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #5 on: 07 November 2010, 13:21:57 »
 ;D Only joking about replys Rob, Either way I think the ECU is toast as I had the prob with fueling prior to the blow up. Anyone know whats required along with a new ECU? I guess keys, immobiliser and ecu would cover it  ::)
The Red Baron
« Reply #6 on: 07 November 2010, 13:31:53 »
i do have all these bits from a 3.0l auto, finding them make take a while though. lol. the key has the extra fob though for the locking. early type.
« Reply #7 on: 07 November 2010, 13:37:33 »
Was it like a very loud whoosh noise?
I'd say more likely a backfire through the inlet, rather than anything 'blown' - hopefully not a cause for concern..
« Reply #8 on: 07 November 2010, 13:38:16 »
If you weren't so far away, I'd pop over for a look  :'(
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #9 on: 07 November 2010, 14:02:01 »
More of a pop with a bit of smoke, tried a new fuel pump so thats ruled out, got to be the ECU methinks!
« Reply #10 on: 07 November 2010, 14:06:56 »
Smoke, or, combustion gasses?
Still reckon was a backfire in the inlet - can't imagine the ECU has failed.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #11 on: 07 November 2010, 14:08:31 »
Acrid burney smell, def something electrical
« Reply #12 on: 07 November 2010, 14:19:21 »
Don't take this the wrong way, but.. the battery was the right way round, wasn't it? I've only known major electrical explosions with reversed polarity, huge overvoltage or incorrect jumping  :-/
What you need is this: http://www3.telus.net/bc_triumph_registry/smoke.htm
(Sorry .. hopefully that will make you chuckle at least!)
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #13 on: 07 November 2010, 14:27:53 »
 ;D ;D ;D Definately on the right way mate, funny link
