Pages: 1 2 [3]  All   Go Down
Author Topic: Front doors deadlocking.....  (Read 3246 times)
Re: Front doors deadlocking.....
« Reply #30 on: 06 November 2010, 20:30:44 »
::)i meant to say make sure when you are doin the procedure make sure the doors are closed (and you are in it of course) and its lock 1st then unlock.
Key fob will not lock the car with the ignition switched on.......... so could not use this process to reset.. :(
« Reply #31 on: 06 November 2010, 20:32:29 »
Double checked that the key fob locks and then deadlocks in two movements, it does.... ::) ::)
Key will neither lock or unlock the door mechanically, key simply will not move in any direction..???
Fob works fine though.....
« Reply #32 on: 07 November 2010, 20:13:02 »
Tried it again today with the original key, rather than the replacement and still no movement, key will not turn to either lock or unlock the car........ :(
My worry is if the fob were to fail I could not get in the car..... :'(
Where do I go next.....??
« Reply #33 on: 07 November 2010, 20:15:41 »
Ahh, starting to sound to me like the lock barrel in the door has siezed up.
Is it worth taking it out , stripping it down, lubricating and removing any burrs on the levers? Not sure how. Never had one apart before.
« Reply #34 on: 07 November 2010, 20:22:09 »
Do you think this cause the button problem Kevin? I have stripped the door to sort the locks twice on a pre-facelift.....Or suss out a local auto locksmith.... :)
« Last Edit: 07 November 2010, 20:30:16 by floodm »
Pages: 1 2 [3]  All   Go Up
