Author Topic: Engine trouble above 3thous revs  (Read 1407 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 16 November 2010, 21:13:19 »
Hi all,I've been looking for a water leak today at the rear of the plenum with no look but have got in the car to drive this evenin and car won't rev above 3000 revs it's like car hits the limiter eml light then comes on then take my foot off throttle and all is well again.any ideas what the hells goin on?have knocked something?
scream if you want to go faster!!!
  • Auckland
    • Mazda MPV
Re: Engine trouble above 3thous revs
« Reply #1 on: 16 November 2010, 21:18:29 »
You are hitting the rev limiter.
When the EML light is showing the ECU applies a much lower rev limit.
Do the paper clip test and see what code is stored :y
mr ICE man
  • dolgellau wales
« Reply #2 on: 16 November 2010, 21:21:23 »
No,eml light is not on.it flashes on and goes off,car is not in limp mode.
« Reply #3 on: 16 November 2010, 21:32:31 »
Do the paper clip test and see what codes are stored ;)
mr ICE man
  • dolgellau wales
« Reply #4 on: 17 November 2010, 07:57:29 »
As predicted no codes stored just 19 and I've replaced the sensor with genuine part so don't think it's that.
Welung666
« Reply #5 on: 17 November 2010, 08:03:26 »
I can put the laptop on it when you come down if that's any help?
mr ICE man
  • dolgellau wales
« Reply #6 on: 17 November 2010, 14:06:42 »
had a good look today and all connections are good.it sound like a missfire.all dispack leads are plugged in.it revs to 4thou and then bounce back to 3500 as if its hitting 6500.i am very confused and gettin sick of it.
« Reply #7 on: 17 November 2010, 14:31:52 »
remember, just cos you have replaced a part, there is no guarantee that part is not faulty.
mr ICE man
  • dolgellau wales
« Reply #8 on: 17 November 2010, 16:40:16 »
got my trusty "My Naff Code Reader" working and have cleared codes,started engine and code 19 again!so must be crank sensor again?what a pain!do vx do warrenty as its not even 6 months old!
