Author Topic: urgent lead layout  (Read 1173 times)
millwall
  • se london
  • no muff too tuff
    • accord type s
urgent lead layout
« on: 24 November 2010, 12:43:20 »
hi all just replacing my leads  and got a problem
Dis Pack:    2        6        4
                  5        3        1
                    Front of car
Engine:        5              6
                   3              4
                   1              2
                  Front of car
ive removed the leads from 6 4 2 on the pass side bot just realised  in the pic my dis pac is a different layout as on the dis layout shown i have removed the 1 3 5 leads if that makes sense    the oval connector for the dis is is on the left (driver side) is it just a case of the dis is fitted the wrong way round
« Last Edit: 24 November 2010, 12:44:16 by millwall »
skyblue
  • Bracknell
Re: urgent lead layout
« Reply #1 on: 24 November 2010, 12:46:30 »
the leads should be cut to lenght for each plug... ie longest lead is to the furset plug abd so on
HTH
« Reply #2 on: 24 November 2010, 13:03:22 »
Dis Pack:    2        6        4
                  5        3        1
                    Front of car
Engine:        5              6
                   3              4
                   1              2
                  Front of car
                                 Bulkhead
                       ......5............3................1.
PLUG
                        ......2............6................4.
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #3 on: 24 November 2010, 13:12:17 »
robg you are a gent   makes sense now   thank you :y
Matchless
  • Nottingham
    • A white van
« Reply #4 on: 24 November 2010, 13:13:01 »
The arrangement you have will work OK. There are 3 separate double-ended coils within the pack so the 1-4 coil can be connected to plugs 1 & 4 or 4 & 1, it doesnt matter if they are swapped. (if you see what I mean) When plug 1 is fired, plug 4 also fires, but since that cylinder is on the exhaust stroke it has no effect.
Best to make the leads match up with the numbers moulded into the pack though, less chance of an error that way.
Edit, just re-read and realised your coil pack is fitted the opposite way to normal. I will shut up now.
« Last Edit: 24 November 2010, 13:15:40 by Pete »
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #5 on: 24 November 2010, 16:26:52 »
just a quick update   leads are done  thanks to the help on oof :y
car is now running very nicely  no more misriring and idles perfect :)
Page created in 0.063 seconds with 16 queries.
