Author Topic: temp guage  (Read 1526 times)
moose
  • SWINDON WILTS
temp guage
« on: 16 November 2010, 10:13:59 »
hi all , my temp guage does not move at all any more but all rad pipes are warm and heater works ok.can anyone tell me where the sensor is as i think it needs replacing or is there something else i should be looking at ,,,thanks in advance...marcus.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: temp guage
« Reply #1 on: 16 November 2010, 10:36:10 »
i believe its under the air intake plenum towards the rear. ;)
Re: temp guage
« Reply #2 on: 16 November 2010, 11:12:14 »
it is... Have you had the plenum off recently or done any work down the back (dis pack for example) as you may be lucky and just have dislodged the spade connector.
moose
  • SWINDON WILTS
Re: temp guage
« Reply #3 on: 16 November 2010, 11:17:13 »
hi,no work done recently but will check connection now i know where it is
Re: temp guage
« Reply #4 on: 16 November 2010, 11:39:52 »
Could be thermostat stuck open  :(
moose
  • SWINDON WILTS
Re: temp guage
« Reply #5 on: 16 November 2010, 12:05:43 »
ok on closer inspection the needle moves very slightly but not much,even after ticking over for 20 mins,can you tell me where thermotat is and how easy to change...cheers.
The Red Baron
Re: temp guage
« Reply #6 on: 16 November 2010, 12:09:41 »
again, under the plenum at the front in the V of the heads. never had to change one but i believe its not that easy dependant on a certain bolt. ::)
skyblue
  • Bracknell
Re: temp guage
« Reply #7 on: 16 November 2010, 12:25:59 »
Dont make the same mistake as I made when ordering the new stat as you will need to ask for  two new shorter bolts to bolt it down with .... otherwise you will be curseing like I was after all that work u have just done.  ::) ;)
Re: temp guage
« Reply #8 on: 16 November 2010, 12:26:53 »
or use a hacksaw  :y
skyblue
  • Bracknell
Re: temp guage
« Reply #9 on: 16 November 2010, 12:32:35 »
or use a hacksaw  :y
for the price of a new bolts and a load of swearing forget the hacksaw as it wont get the stat out for ya any easier  ;) ;D
Re: temp guage
« Reply #10 on: 16 November 2010, 12:48:26 »
or use a hacksaw  :y
true, but 1/2 way through the job when you discover the bolt issue, its a very good idea at the time  :y
Re: temp guage
« Reply #11 on: 16 November 2010, 17:31:33 »
Before changing things willy-nilly .. how about a simple check ???
Start engine from cold .. leave to idle whilst standing with one hand on the big pipe that goes from the thermostat to the top right (as you face the engine) of the radiator.
One of 2 things will happen ... EITHER the pipe will slowly start to warm up and never get really hot .. OR the pipe will stay cold until a sudden rush of fairly hot water passes through (there is a 3rd possibility but that is linked to overheating so does not apply here.....   :)  )
If the pipe very slowly heats up .. the thermostat has failed open .. it needs replacing.
If the water stays cold until a sudden surge of fairly hot water .. the thermostat is working .... in which case it is probably an indication problem.
It is, rarely though, possible for the thermostat to work but at too cool a temperature, in this case the "surge" of heat will be mush cooler than "fairly hot" .. if that makes sense .. :)
HTH
moose
  • SWINDON WILTS
Re: temp guage
« Reply #12 on: 16 November 2010, 22:21:36 »
thanks will try in the morning !!
moose
  • SWINDON WILTS
Re: temp guage
« Reply #13 on: 27 November 2010, 16:59:26 »
thanks for all the help guys ,,seems thermostat was stuck,got it changed now temp reads 87 and the heater is a lot warmer...thanks until next time !!!
