Author Topic: French Connection  (Read 1303 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
French Connection
« on: 27 November 2010, 14:06:23 »
Just got back from four days in France, (that tunnel is great) 700 trouble free miles - well nearly. My remote key unlocking failed, (since OK with new battery), fortunately, I had taken my spare key, so not a problem, but I am frequently out with only one key, and my question is, how do you cancel the alarm after opening the car with the key blade?
Varche
  • middle of Andalucia
    • Golf Estate
Re: French Connection
« Reply #1 on: 27 November 2010, 14:30:47 »
Eurotunnel is good but a great terrorist target.
I had a similar thing with mine recently. I found the alarm stopped when you got the key in the ignition and started it up. Most embarrassing.
Shackeng
  • Ramsbury
« Reply #2 on: 27 November 2010, 16:14:14 »
 :y :y :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #3 on: 27 November 2010, 18:03:30 »
...how do you cancel the alarm after opening the car with the key blade?
You just need to turn the ignition on.
You can also lock the car with out the alarm setting (saves annoying the neighbours) by reaching through an open rear door and pushing the 'plunger' on the drivers door. Be aware though, the dead locks won't be on...
MV6Man
  • Finland
« Reply #4 on: 28 November 2010, 06:53:01 »
I thought that deadlock and alarm won´t go on if key lock button is pressed just once. ?
Shackeng
  • Ramsbury
« Reply #5 on: 28 November 2010, 11:49:24 »
My OP was about when the key electrics fail. :y
