Author Topic: Replacing the thermostat  (Read 2295 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« on: 23 November 2010, 11:30:05 »
Is it advisable to replace the whole unit (expensive) or is it OK to replace just the thermostat (cheap).
I like red cars
Re: Replacing the thermostat
« Reply #1 on: 23 November 2010, 11:42:14 »
Think most replace the housing too, Im sure the design has changed and often the pipe that attaches to it as well (or at least the orings)  You need shorter bolts too, or a hacksaw  :y
« Last Edit: 23 November 2010, 11:42:48 by jimbob »
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #2 on: 23 November 2010, 11:43:24 »
Cheers. :y
I like red cars
« Reply #3 on: 23 November 2010, 11:44:25 »
The omega stat comes in the housing. Don't know if there is facility to swap out the innards. Guessing not... :-/
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #4 on: 23 November 2010, 11:49:03 »
Yes, I know that, but you can buy the thermostat separately (aftermarket), I just wondered if anyone had done that.
I like red cars
skyblue
  • Bracknell
« Reply #5 on: 23 November 2010, 13:02:47 »
When I got mine from our vax dealer the price quoted was just for the stat a nice round sum of 54 quid..... afternarket selller wasnt much cheaper either
« Reply #6 on: 23 November 2010, 23:11:50 »
Thermostat is under plenum front of block, think there's a guide, always worth a search  :)
serek
  • huntingdon
    • 3.2 mv6
« Reply #8 on: 24 November 2010, 15:31:28 »
yes you can buy separately, done on my cars few times :y
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #9 on: 24 November 2010, 17:19:33 »
I've just replaced a thermostat, during  my engine rebuild. I didn't need to take apart the housing and pipe where I had the engine apart. The advice by an Vauxhall mechanic that I was talking to when I went to buy the housing gasket, not realising this is supplied as part of the kit, which I had ordered of Ebay, is that the housing quite often breaks when you do this, which is why the whole unit often needs replacing.
Once you have the housing off it take about 2 minutes to change the thermostat using the cardboard tube supplied in the kit to remove the old one and inset the new one.
The thermostat kit cost £7.20 on Ebay and is QH brand, compared to £23-25 for the complete unit. If you just buy the thermostat, it would probably be a good idea to get a replacement o-ring for the pipe and housing joint as this does not come as part of the kit.
I hope this is of help.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #10 on: 24 November 2010, 17:57:26 »
Thanks for all the advice :y
I like red cars
« Reply #11 on: 24 November 2010, 18:30:46 »
Beware though, I have seen a few housings where the casting had been erroded away around the stat seat.
« Reply #12 on: 24 November 2010, 19:10:58 »
Yet another reason to completely ignore what 'vx trained technicians' say ;)
Greeny18
  • Sandy, Beds
    • 2001 2.6 Estate
« Reply #13 on: 03 December 2010, 22:55:09 »
Does anyone know the part number for the coolant transfer pipe for a Y26SE V6 Omega
« Reply #14 on: 04 December 2010, 10:39:59 »
Need 2 seals at end as well (which you may have if you were planning on changing stat), though these vary with engine no.  The pipe itself is same across all V6s.
 12 90411629 13 38 320 PIPE, THERMOSTAT HOUSING TO HOSE    1
 13 90410899 13 38 471 SEAL, RING  (E)
(E)  -08378122
      -14393646
 2
13 9129999 13 38 202 SEAL, RING
(E) 08378123-
(E) 14393647-
 2
« Last Edit: 04 December 2010, 10:41:12 by TheBoy »
Page created in 0.033 seconds with 20 queries.
