Author Topic: Did the snow do it??  (Read 2602 times)
Daz1111
  • Norwich
« on: 30 November 2010, 14:09:41 »
Hi all, I have a problem with my outside Temp. gauge.
Since it started snowing it just reads 'F' where the number should be. The climate control has gone nuts (currently set to 27 degrees just to get some warm air!)
Does the F simply mean fault? and where is the sensor on a 52 plate Est?
Thanks ;D
Re: Did the snow do it??
« Reply #1 on: 30 November 2010, 14:11:46 »
Have you got a load of snow up against, and under, your front bumper?  The sensor is under the front lower panel, so it could well be affected ;) ;)
Daz1111
  • Norwich
« Reply #2 on: 30 November 2010, 14:16:33 »
don't know, I'll have a look
Daz1111
  • Norwich
« Reply #3 on: 30 November 2010, 14:25:55 »
What side is the sensor?
« Reply #4 on: 30 November 2010, 14:26:56 »
Middle of bumper
« Reply #5 on: 30 November 2010, 14:27:01 »
Towards the centre usually ;)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #6 on: 30 November 2010, 14:33:22 »
If the sensor is on its way out, the extreme conditions tend to tip them over the edge..... easy to replace (just pop out and swap), and can be had for around a fiver  :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
Daz1111
  • Norwich
« Reply #7 on: 30 November 2010, 14:42:06 »
Thanks - found it.
No snow but is quite wet - shouldn't cause a problem as it must get wet everytime it rains!
do I take it that the only way to check it works is to change it?
« Reply #8 on: 30 November 2010, 14:43:34 »
Thanks - found it.
To my knowledge, yes, but others may have another idea.  For £5 it is not worth mucking around for in my opinion ;)
Daz1111
  • Norwich
« Reply #9 on: 30 November 2010, 14:46:40 »
Just read on another forum (sorry!!) that the 'F' stands for freezing!
Can that be right as the temp gauge normally goes well below 0?
« Reply #10 on: 30 November 2010, 14:48:21 »
lol NO! ;D ;D ;D ;D
It stands for Fahrenheit, or you can select "C" for celsius :D :D ;)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #11 on: 30 November 2010, 14:59:30 »
come on lizzie you know on other forums
F= freezing
C= cool
H=hot
 ;D ;D ;D ;D
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #12 on: 30 November 2010, 15:31:04 »
it stands for something other than freezing that still begins with F and ends with D
other rides
fergy
  • Hereford
  • 2001 CDX 2.2dti Estate
« Reply #13 on: 30 November 2010, 19:46:10 »
Drove through some deep flood water once and temperatature gauge fell about  half a degree every 2 seconds... all the way down to -37 degrees C. at which point it stopped and displayed  "F degrees C"
 I guessed this to mean "Fault." Took the sensor off, dried it out  in airing cupboard and put it back on ... all back to normal.  It happened once again when the scuttle drain was blocked up. Got rid of the water in the car, and just let it all dry out naturally, Its been alright since!
dodgy
  • Hants
« Reply #14 on: 05 December 2010, 22:50:13 »
Mine is playing up too. It is saying +65 degrees and you don't normally get snow when it is that hot  ;D
Seems to move + or - 5 degrees from there within a mile or two. It also seems to muck up the heating system, I guess because the climate control thinks it is letting in hot outside air when in fact it is freezing !
Thanks for the pointer to the location of the sensor. I'll take a look at it.
Dodgy
X reg 2.2 estate
