Author Topic: Self Leveling Sensor  (Read 1441 times)
Boditza
  • Craiova, Romania
« on: 07 December 2010, 11:47:24 »
This is what happened to mine..
http://img607.imageshack.us/i/11052010027.jpg/
http://img808.imageshack.us/i/11052010026.jpg/
 from the previous owner. He also mounted regular shock absorbers because he said that with this sensor the car lifted ridiculously high. I wonder if i manage to improvise that pawl that is broken will it work again?? Have you encountered any sensors that simply are broken electricly? i am hoping that mine works perfect but it doesn't stop where it is suposed to
Re: Self Leveling Sensor
« Reply #1 on: 07 December 2010, 12:11:46 »
If I'm looking at that correctly, the missing bit is just a stopper for the arm.  :-?
From what has been posted on here in the past, this issue has been blamed on the pump not releasing air. The system pumps up an amount on start up, and sometimes releases air as required soon after. Over time the system pumps up gradually and ands up too high.... Afaik.
If you move the arm when connected, it should pump or release air accordingly.
This might help.
ttp://www.omegaowners.com/forum/YaBB.pl?num=1250308202
And the pump can be heard running in the background of the pedal trick test video in paperclip test under code reading in maintanance section.
Boditza
  • Craiova, Romania
« Reply #2 on: 07 December 2010, 12:30:52 »
so there is 90% chance that the problem is in the pump?? can that be repaired or fixed??
found this:
COMPRESSOR, CAR STAND HEIGHT ADJUSTMENT
(NML-22153582 4 35 712 USE)
20SE, X20SE, X20XEV R1000001-S1000146 (5049210) (4 35 709)
(NML-22153582 4 35 712 USE) U25TD, X25TD
R1000001-T1118026 (5049210) (4 35 709)
U25TD, X25TD T1118027-V1999999 22,153,582 4 35 712
X20DTH, Y22DTH, U25TD, X25TD, Y25TD
W1000001-
22175324
4 35 716
X20DTH-V1999999 22,153,582 4 35 712
if it ain't for my car will it fit from another one??
« Last Edit: 07 December 2010, 12:37:07 by boditza »
Boditza
  • Craiova, Romania
« Reply #3 on: 08 December 2010, 08:47:30 »
i'm annoying i know but has anyone tryed to fix the pump??
« Reply #4 on: 08 December 2010, 08:52:51 »
My personal experience is that its normaly the ECU in the sensor.
Easy to prove with Tech2 as it wont respond to commands
« Reply #5 on: 08 December 2010, 09:04:19 »
Hence suggestion of testing the sensor when connected. If the pump comes on and stays on for a good two minutes at least then the car does not know it's own hight. I would say sensor fault...?
If the pump runs for the usual 5 seconds, or whatever seems normal in the pedal trick video, then might suggest pump problem, ESP if it's not heard to release air at any point.
But if tech 2 is available.....
Boditza
  • Craiova, Romania
« Reply #6 on: 08 December 2010, 09:04:36 »
:-* :-* :-* :-* :-* :-* :-* the bearer of good news. will it show up on "My Naff Code Reader"? what comands does it has to comply when conected to diagnostic cable?
« Reply #7 on: 08 December 2010, 09:05:07 »
Plus I believe the pump is a sealed unit. But what's to loose if your sure it's the pump at fault?
« Last Edit: 08 December 2010, 09:06:03 by chrisgixer »
Boditza
  • Craiova, Romania
« Reply #8 on: 08 December 2010, 09:08:51 »
i have a 2,2 dti so i guess the pedal trick is out of the question, and for my shame i have not tested teh sensor i already have, but will try to do it this afternoon if the time will alow it.
bottom line is that the pump should work for ~5 secs right? amd when i will "unload the car" there should be a sound of releasing air right??
Page created in 0.199 seconds with 16 queries.
