Author Topic: Air bag light  (Read 1413 times)
Stagecoach
  • Fontwell, West Sussex
Air bag light
« on: 26 December 2010, 12:08:34 »
Hi. I have now fitted 3 squibs but airbag light remains on. I am told possibe seat belt tensioners. How do I check these. Thanks Kev
« Last Edit: 26 December 2010, 12:08:56 by Stagecoach »
Re: Air bag light
« Reply #1 on: 26 December 2010, 12:11:08 »
You can chop & change as many parts of the SRS system as you like but without a proper code reader such as Tech II you will never find and/or eradicate the fault
Re: Air bag light
« Reply #2 on: 26 December 2010, 12:14:28 »
It doesnt matter if you fix the fault....the light will remain on untl yuo turn it off with a diag computer.  Have you got one / had it plugged in?
If not, where are you, someone local may be able to help.
« Last Edit: 26 December 2010, 12:15:04 by jimbob »
Re: Air bag light
« Reply #3 on: 26 December 2010, 12:15:17 »
even if you fix the fault by fitting a working squib/airbag/tensioner/etc the light will remin lit till reset with a code reader of sorts.  ;) As Rob says, you need a reader to ask your car what's up, and then go from there.  :y  :y
Stagecoach
Re: Air bag light
« Reply #4 on: 26 December 2010, 12:32:08 »
I had the code read by a friend in Blackpool who advised a squib change and was told the light should go out after fitting. I have one of those cheap ebay tech2 readers/resetters, but does not seem to work on my car. I am in Worthing, Sussex
Stagecoach
Re: Air bag light
« Reply #5 on: 26 December 2010, 12:33:05 »
Re: Air bag light
« Reply #6 on: 26 December 2010, 12:35:57 »
The air bag light is the only fault that won't self reset.
Mmm?  My 'cheapo Tech II' will  :-/  :-/ I've used it on my Astra & a couple of other Omega's SRS light.
