Author Topic: Air filters........  (Read 1470 times)
Debs.
Air filters........
« on: 12 January 2011, 22:20:07 »
....for my `99 2.5 V6.: the motor factors list 2 types of the same brand with the same rectangular dimensions, but as best I can figure, the only difference is in the depth of the pleats and an additional stiffening/support rib. :-/
Was there a model year change of filter?.....or is the deeper pleated filter an engine-performance/greater-flow requirement for the later 2.6/3.2`s?
Welung666
Re: Air filters........
« Reply #1 on: 12 January 2011, 23:17:46 »
There are 3 types Debs... Vx genuine, motor factors better quality and motor factors cheap sh!te. You'll be fine with the first 2 ;) Avoid the 3rd option.
If you imagine the surface area difference between the deeper pleat and shorter pleat, which gets clogged up first? ;)
« Last Edit: 12 January 2011, 23:18:41 by Welung666 »
« Reply #2 on: 12 January 2011, 23:23:31 »
An OE filter is about £12 inc vat  :y
Omega      Part Number      Retail Price      Normal Trade      Trade Club
Air filters
All models      91149684      £16.00      £13.61      £9.92
andyc
  • Norfolk
« Reply #3 on: 13 January 2011, 09:03:19 »
yes only one listed for all Omegas
« Last Edit: 13 January 2011, 09:03:48 by andyc »
Thetford. Norfolk
Debs.
« Reply #4 on: 13 January 2011, 09:10:01 »
Thankyou all! :y
« Reply #5 on: 13 January 2011, 09:18:09 »
You should have said when you were here last Debs ;D
Debs.
« Reply #6 on: 13 January 2011, 12:12:27 »
 :y Next time; "ve vill examine zee lizst!" ;D
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #7 on: 13 January 2011, 12:30:46 »
I think the same must apply to pollen filters. My 2.5 has a meaty looking 3M filter but the 3.0 has a rather chatty looking paper thin Airflow one.
mathewst
  • Split, Croatia
    • v40
« Reply #8 on: 13 January 2011, 12:35:10 »
Varche there are two types of pollen filters.
Paper ones and carbon ones
Debs.
« Reply #9 on: 13 January 2011, 12:42:54 »
This why I asked:
The Coopers filter (AG1173) has much less depth and fewer pleats than the Wix (WA6621) and the latter has pleat-stiffeners; at both top and bottom...a much better quality item. (£8.90 inc. VAT) :y
« Reply #10 on: 13 January 2011, 12:53:01 »
Hard to tell with the scale but that wix looks viertually identical to GM :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #11 on: 13 January 2011, 23:16:03 »
Yep, probably out of the same factory.  ::)
