Author Topic: Vacuum hoses  (Read 1948 times)
zirax
Vacuum hoses
« on: 13 January 2011, 22:40:48 »
I've had a look at my Omega and I think there is a vacuum pipe missing. It is the one going from the T-piece of the front multi-ram to the vacuum res at the bottom of the inlet ducts. Does anyone know a part number for this?
Dr Richard Stephens:- "I would advise people, if they hurt themselves, to swear."
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Vacuum hoses
« Reply #1 on: 14 January 2011, 08:06:07 »
from what seen on here it gose no were just sits at the back of the engine but maybe wrong but thats what seen in old posts.
Solar charger fitted.
If not Broke dont fix it..
Re: Vacuum hoses
« Reply #2 on: 14 January 2011, 08:17:38 »
ignore the prat above, he is refering to a gearbox breather at the back of the engine, not the multiram system at the front  :y
Dont think vacuum pipes have part numbers, are just cut off the roll in effect, beleive a decent factors should have it.
Welung666
Re: Vacuum hoses
« Reply #3 on: 14 January 2011, 08:34:17 »
Is this the one that comes off the bottom of the front of the plenum and runs up underneath the plenum to the rear of the engine?
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Vacuum hoses
« Reply #4 on: 14 January 2011, 10:46:48 »
Does anyone have dimensions for these hoses? 3mm/4mm or what size are they?
The one under the front of plenum seems to be quite loose on many omegas and does not affect that much... I have no noticed any difference when it has come off...
Re: Vacuum hoses
« Reply #5 on: 14 January 2011, 10:51:50 »
Any body breaking omegas will have a few miles of the stuff, certainly the guy in Heathrow was giving it away, with other purchases.
Maybe a wanted add here. ?
But is it worth posting a Picture so we can be sure?
Re: Vacuum hoses
« Reply #6 on: 14 January 2011, 10:51:57 »
mahony
  • london
    • omega elite 3.0
Re: Vacuum hoses
« Reply #7 on: 14 January 2011, 12:19:49 »
i replaced the rubber vacuum hose  next to the servo  a few weeks back, 4mm fitted perfectly  :y
« Last Edit: 14 January 2011, 12:21:06 by mahony »
Welung666
Re: Vacuum hoses
« Reply #8 on: 14 January 2011, 18:44:21 »
I've got a load here if you need any, I also have 90 degree and traight through rubber connectors :y
zirax
Re: Vacuum hoses
« Reply #9 on: 14 January 2011, 20:43:04 »
Does this help in any way ???
http://www.omegaowners.com/forum/YaBB.pl?num=1152565204
Yep, it is the piece that goes from the Res to the T-piece behind the inlet hose.
I may take you up on that offer! I will have a proper look under the bonnet tomorrow and check that is the only piece I need.
edit: A picture does say a 1000 words so I will sort a pic out tomorrow as well
« Last Edit: 14 January 2011, 20:44:30 by zirax »
Page created in 0.025 seconds with 16 queries.
