Pages: [1] 2 3  All   Go Down
Author Topic: v6 cam belt  (Read 6634 times)
sierrapaul
v6 cam belt
« on: 16 January 2011, 13:59:49 »
if a 3 litre v6 jumps a couple of teeth om the cam belt whats the chances of valve damage?.its ronning as rough as hell and weve checked every sensor and the coil pack and plugs and leads and everythings working as it should.and te belt jumping is all that it can be and it sounds tappy from the top end
Danny
  • Wigan, Greater Manchester
Re: v6 cam belt
« Reply #1 on: 16 January 2011, 14:06:30 »
if you know its definately jumped a couple of teeth, have you tried to refit?
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: v6 cam belt
« Reply #2 on: 16 January 2011, 14:10:02 »
depends which cam & how many teeth tbh.
sierrapaul
Re: v6 cam belt
« Reply #3 on: 16 January 2011, 14:11:46 »
havent had the covers off it yet.as weve tryed everything else this is the only thing i can think of.its saying cam sensor voltage to high.and my thinking is as its a new cam sensor and its running the belt jumpping is all i can think off cos we tried the cam sensor on my v6 calibra and that ran fine
sierrapaul
Re: v6 cam belt
« Reply #4 on: 16 January 2011, 14:14:38 »
and my mates just told me its due a belt so i think it strip it down time.if it was out whats chances of valve damage?
The Red Baron
Re: v6 cam belt
« Reply #5 on: 16 January 2011, 14:16:20 »
does it tick over very rough/wants to stall.
will it rev over 2k & sound ok?
sierrapaul
Re: v6 cam belt
« Reply #6 on: 16 January 2011, 14:20:36 »
it ticks over and sounds like a bag of nuts n bolts it will rev but very hesitantly as soon as you put it in reverse or drive and touch the throtle it dies but will move back and forwards if you dont touch the gas
The Red Baron
Re: v6 cam belt
« Reply #7 on: 16 January 2011, 14:29:53 »
is it popping from the air intake plenum on tickover?
sierrapaul
Re: v6 cam belt
« Reply #8 on: 16 January 2011, 14:37:51 »
no only when you rev it on tick over it sounds like its running on 2 cylinders
The Red Baron
Re: v6 cam belt
« Reply #9 on: 16 January 2011, 14:44:20 »
take the EGR valve off, give it a good clean inside with carb cleaner, or you could just make a blanking plate up at its base. x2 torx bolts. this may sort you out.  :y
sierrapaul
Re: v6 cam belt
« Reply #10 on: 16 January 2011, 14:47:26 »
blanked the egr valve when first got it as it was leaking
The Red Baron
Re: v6 cam belt
« Reply #11 on: 16 January 2011, 14:52:41 »
bugger.
sierrapaul
Re: v6 cam belt
« Reply #12 on: 16 January 2011, 14:57:07 »
im all outa ideas with it.think its time to get the matches out and have bonfire nite early
The Red Baron
Re: v6 cam belt
« Reply #13 on: 16 January 2011, 15:01:38 »
mmmmm
have you had owt to bits on the inlet/plenum. check all vac connections are tight. other than that, yes check the situation of the cambelt. if valves were hitting pistons then you would have a loud knocking not a tappy sound. i did manage to save a 3.0l that went a few teeth out. :y
sierrapaul
Re: v6 cam belt
« Reply #14 on: 16 January 2011, 15:09:15 »
think il have to have the cover off and check timeing.thanks for your help
Pages: [1] 2 3  All   Go Up
Page created in 0.255 seconds with 16 queries.
