Author Topic: quick answers please?  (Read 1960 times)
Omegatoy
  • UK
« on: 20 January 2011, 18:49:55 »
mate of mine has just asked
whats the review for a 2.5 cdx omega how many miles to the gallon etc and what should I look for
2.5petrol
I'm looking at a T reg manual with 180,000 on the clock no faults listed full spec inside leather climate etc etc
being as i aint keen on the petrol omegas though i would throw it out here for you experts to advise me
Re: quick answers please?
« Reply #1 on: 20 January 2011, 19:00:53 »
our 3.0 manual gets mid 20's round town, low to mid 30's on a run
« Last Edit: 20 January 2011, 19:01:12 by jimbob »
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #2 on: 20 January 2011, 19:18:45 »
My 2.5 gives about 22 to 25 round town and goes up to about 32 to 33 on a gentle run.
A heavy right foot makes a huge difference!
best wishes
Simon.
Omegatoy
  • UK
« Reply #3 on: 20 January 2011, 19:48:30 »
hmm he does have rather large feet at times!!
Omegatoy
  • UK
« Reply #4 on: 20 January 2011, 20:05:55 »
no worries about the high mileage then? is the 2.5 petrol a good engine? no worries on flywheels etc? i really know very little about them!!
jonathanh
  • coventry
« Reply #5 on: 20 January 2011, 20:06:23 »
you should get 30mpg even in town, 36 on a long run if you are careful.  however if you are "spirited" could go as low as low 20s
2.5 manual is about best for performance economy.
Omegatoy
  • UK
« Reply #6 on: 20 January 2011, 20:09:16 »
thats good to know!! he is reading the replys and will be joinging if he gets it im pretty sure but need more input!!
come on guys??
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #7 on: 20 January 2011, 20:23:56 »
High milage is a non issue so long as oil changes and cambelt changes have been done on time
other rides
bigdods
  • Brackley
« Reply #8 on: 20 January 2011, 21:09:31 »
And the water pump. My old 2.5 CDX expired 8 miles after I sold it. Water pump was leaking and I told him it wouldnt get far. It let go after about 5 miles and he drove it another 2 or 3 before the engine seized.....
« Reply #9 on: 20 January 2011, 21:13:46 »
23-24 urban , 32-33 on a "normal" run..
depends on the traffic though..
but seen 9mpg avg  continous hammering ;D
« Last Edit: 20 January 2011, 21:16:08 by cem_devecioglu »
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #10 on: 21 January 2011, 11:11:26 »
my 2.5 cdx does approx 25-28mpg town 30-33mpg 70mph motorway and approx 25-28mpg 100+ motorway driving (didnt say that)  :P   its on a t plate and done 150,000 but regular oil changes and cambelt just been done  :y
« Reply #11 on: 21 January 2011, 12:25:38 »
As has been said, mileage not necessarily a problem if it's been looked after. Neglected oil changes will block the breathers and cause the cam cover gaskets to fail. Not a desperate problem to fix, but a good bartering point. Worth a few quick oil changes to clean it out, and a clean of the breather system if the current oil looks a bit tired.
Likewise, neglected coolant causes the oil cooler to corrode and you get oil in the coolant. Play the "it's the head gasket" card to beat the price down then swap the oil cooler. Parts a little over £100 for that job. :y
Can also corrode the oil cooler cover plate and cause a leak. Coolant leaks from the head gaskets not unheard of, again, caused by neglected coolant.
Cam belt must be done every 40k / 4 years. Not a difficult job for a man of your calibre but another bartering point. :y
Multiram system can often fail or the vac pipes be damaged / badly connected. Not an issue to fix normally.
Might find a noisy SAI blower under the passenger side wheel arch. Not an issue, can be disconnected / removed.
Exhaust manifold gaskets can blow, and are awkward to change. Especially noticeable for the first few seconds after a cold start.
Does have a DMF but the relatively small number of issues we see suggests it's reliable. If it's on the original clutch that might not be long to this world, of course.
Check all the panel lights come on and extinguish individually after engine start. ABS/TC failure not unknown, so check speedo works reliably. Might be worth taking a paperclip and reading the guide to code reading.
Other than that, I'm sure you're aware of all the body / chassis issues, G. :y
Omegatoy
  • UK
« Reply #12 on: 21 January 2011, 19:36:25 »
excellent!!
yep know most about them but have tried very hard to avoid the v6 as its just not my cup of tea !! hence the questions on here,
so thanks a lot guys very informative :y will let you know how it turns out!!
