Author Topic: Cruise Control Retrofit  (Read 1563 times)
zuluf
  • Valpovo, Croatia
« on: 17 January 2011, 20:51:11 »
I can swear I saw some guides or at least some pointers on how to do it on the forums but apparently I cant find it anymore.
I would kindly ask if anyone knows to point me/give link to "How To" for retrofiting CC on Omega B '97.
Thank you!
Debs.
Re: Cruise Control Retrofit
« Reply #1 on: 17 January 2011, 20:59:21 »
zuluf
  • Valpovo, Croatia
« Reply #3 on: 17 January 2011, 22:36:45 »
Yes, those! Thanks guys for help.
Now after running through them I got dissapointed a bit. A lot more work than I imagined in the first place (or at least as I remember it when I first read it)
Anyhow, will give it a thought. Thanks again.
  • Online Online
« Reply #4 on: 18 January 2011, 00:16:38 »
you need the loom for cruise module on the driver's side suspension turret.
« Reply #5 on: 18 January 2011, 09:56:11 »
Main problem with 2.0 & Cruise Control, is finding the cruise cable bracket for the cam cover. Only 2.0 CDX had them, which here in the UK were not that common.
zuluf
  • Valpovo, Croatia
« Reply #6 on: 20 January 2011, 15:05:56 »
Is it possible to Frankenstein-ize something from v6 model?
edit: Or frankie something of a facelift 2.2 model? TBH I don't get all the pieces how CC's supposed to work on my model.
« Last Edit: 20 January 2011, 15:07:59 by zuluf »
« Reply #7 on: 20 January 2011, 15:07:52 »
iirc, the 2.0 had a longer cable than any other.
Hard to find.
iirc vectra ones are compatable should you find one.
« Reply #8 on: 20 January 2011, 23:08:46 »
V6, nope totally different plenum mount, 2.2 has an electronic throttle body so no cables, its going to be tough to find, check eBay for ones being broken  :y
zuluf
  • Valpovo, Croatia
« Reply #9 on: 22 January 2011, 10:52:32 »
...well, I think I'll put it on my "lets do it when you have time/money or you bump into something that you need" list.
If anyone has some more ideas don't restrain yourself :P
Anyhow, thanks for help guys!
Page created in 0.04 seconds with 16 queries.
