Author Topic: Wet Windscreen  (Read 2560 times)
J18BES
Wet Windscreen
« on: 18 January 2011, 23:20:40 »
after the car has being sat over night the inside the windscreen seems wet and takes me ages to clear in the morning.
ive checked the car over and nothing wet on the inside
any ideas?
dbr
  • north east.
    • 1997. 2.5CD petrol
Re: Wet Windscreen
« Reply #1 on: 18 January 2011, 23:32:05 »
I also have the same. just have a decent chamois.
Agemo
  • Cleethorpes
  • Insignia
Re: Wet Windscreen
« Reply #2 on: 18 January 2011, 23:34:31 »
Me too, it has got worse recently. Checked drains under scuttle, just weather I suppose.
J18BES
Re: Wet Windscreen
« Reply #3 on: 18 January 2011, 23:37:20 »
ok cool ill get the scuttle off tomorrow if get time.
dbr
  • north east.
Re: Wet Windscreen
« Reply #4 on: 18 January 2011, 23:38:51 »
must be.. my drains also clear. I also have a '89 escort ready to meet the 'maker' which has never had a wet floor , but opened it for the first time in 2 weeks yesterday and it was soaking.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Wet Windscreen
« Reply #5 on: 18 January 2011, 23:47:06 »
Damp Pollen Filter?
Re: Wet Windscreen
« Reply #6 on: 19 January 2011, 08:04:26 »
Turn Eco mode off. Run cc on auto....  And does the ac work?
« Last Edit: 19 January 2011, 08:07:30 by chrisgixer »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Wet Windscreen
« Reply #7 on: 19 January 2011, 09:34:11 »
mine was like this when I first got it as it had been stood for a few months,as Chris says if the aircon is working use it as it will dry the car out
other rides
Boditza
  • Craiova, Romania
Re: Wet Windscreen
« Reply #8 on: 19 January 2011, 10:08:32 »
but for ac to work it should be over +5 degrees celsius or else the compressor won't start
J18BES
Re: Wet Windscreen
« Reply #9 on: 19 January 2011, 10:31:59 »
ill give the ac a go before i leave work. well the sun is on it at the mo so im sure it will work a treat.
the car was stud since middle of dec 10. becuase there was coffee on the oil cap witch seems to be going now so figured was condensation.
2woody
  • Northumberland
Re: Wet Windscreen
« Reply #10 on: 19 January 2011, 11:25:20 »
need to get it good and hot to drive off the condensation and generally dry-out the interior. Try leaving it running with everything turned to "hot" for an hour or two.
then clean the inside of the windscreen properly.
bigtoby
  • london
  • omegas rule :P
Re: Wet Windscreen
« Reply #11 on: 22 January 2011, 08:27:43 »
my elite does the same thing mate i reckon just the way they r if carpets r dry then dont worry too much
andy broon
  • aberdeen
Re: Wet Windscreen
« Reply #12 on: 23 January 2011, 17:34:19 »
had the same proplem with my xtrail i just ran it all the time with ac on and seemed to sort it (Y)
diplo-matt
  • Scarborough
Re: Wet Windscreen
« Reply #13 on: 23 January 2011, 21:30:34 »
Press the air re-circ button when u first start then turn it off after ten seconds ago, and give the window a clean with rain-ex
Danny
  • Wigan, Greater Manchester
Re: Wet Windscreen
« Reply #14 on: 23 January 2011, 21:35:52 »
check if all your carpets are dry, clear out the scuttle drains, give the inside of the screen a clean with a good glass cleaner
i've never ever had a problem with the inside of any of my car windscreens holding water, even when the scuttles were blocked on my first omega and the carpets were wet, the glass had been properly cleaned previously and cleared very well with the heating on, i NEVER ever wiped them clean when they were misty, this makes them worse!
