Author Topic: Headlight range waning  (Read 1008 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 25 January 2011, 09:47:12 »
Getting this poping up on starting the car only not as i,m driving. I have checked the conections and all seem good. i have removed the front rod on the sensor and moved the arm up and down after a few time the headlight range moves up and down... which i would think would show the the motors are working ok.
I have also checked the rear sensor and arm and all fine.Anywhere else to check or is it Tech 2 time.
Thank
Steve.
Re: Headlight range waning
« Reply #1 on: 25 January 2011, 09:57:45 »
prob tech2 and see whats its complaining about is easier than stabbing in the dark  :y
SP_3.2
  • Leicester
« Reply #2 on: 25 January 2011, 10:04:14 »
 ;D ;D and it is, never get time in the day to have a good look so it,s me with a light in the dark which is anytime after 5pm
« Last Edit: 25 January 2011, 10:06:28 by SP_3.2 »
« Reply #3 on: 25 January 2011, 10:33:42 »
If it's still operating as intended, it's possible that the wiring has chafed under the front wing and brought up the warning falsely.
I've seen a couple of cars with the warning on the MID but where the ECU is happy after a chat with a Tech 2. If there's a real problem the lights will normally dip fully.
