Author Topic: Senator AR35 onto and omega  (Read 1785 times)
diplo-matt
  • Scarborough
« on: 24 January 2011, 21:35:03 »
Im sure this has been asked before but are there any major differences between the AR35 on my senator and the AR28 on the MV6? I need to do the thrust washer but while im there i may aswell fit a re-built AR35 that ive had kicking around.
serek
  • huntingdon
    • 3.2 mv6
Re: Senator AR35 onto and omega
« Reply #1 on: 24 January 2011, 21:40:08 »
on 3.0 and 3.2 its AR35
on 2.6 MV6 its AR25
there no AR28 gearbox fited to omega
    • 530D M Sport, 330i Coupe
« Reply #2 on: 24 January 2011, 21:42:57 »
It won't work, both are AR35's but the ECU connections are different IIRC. Senator has ALDL connectivity for the Diags whereas Omega has OBDII so the ECU's are different as well.
Omegatoy
  • UK
« Reply #3 on: 24 January 2011, 21:51:45 »
correct!!! :y
diplo-matt
  • Scarborough
« Reply #4 on: 25 January 2011, 18:51:21 »
Bastard, can the connections not be changed?
« Reply #5 on: 25 January 2011, 19:08:15 »
and you have an autobox dipstick to house ;)
diplo-matt
  • Scarborough
« Reply #6 on: 25 January 2011, 19:24:42 »
So vauxhall put was already a weak gearbox in the 2.5 into the the 2.6 and expected it to last! The old AR25 could barely cope with the old 2.0 ohc engine!
The more i work on omegas the more vauxhall infuriate me, pency pinching everywhere on what essentially is a superb car built on the cheap, the reason i need to change the box is because of the Thrust washer issue which i beleive mine has!
I might just pull the engine out and stick a 12v straight six in it!
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #7 on: 26 January 2011, 21:33:36 »
Haha. Like the logic!
A straight six 12v....reminds me of happy times  8-)
