Author Topic: Can not get waning dispaly off screen  (Read 2051 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 31 January 2011, 18:23:42 »
When i press the brake padal the check display moves on to the waning display as icey road  and so on. When i press the steering wheel controls to remove it it will not go and can not get the normal screen back up showing temp, time, mpg and so on. Any tips to get it back.
Thanks Steve.  :y
« Last Edit: 31 January 2011, 21:05:53 by SP_3.2 »
    • 530D M Sport, 330i Coupe
Re: Can not get waning dispaly of screen
« Reply #1 on: 31 January 2011, 19:00:31 »
What happens if you tap the right hand control knob on the head unit?
SP_3.2
  • Leicester
« Reply #2 on: 31 January 2011, 19:26:24 »
Was getting no joy from that normal that would do the job and get it back to the main screen :-/ :-/
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
Re: Can not get waning dispaly off screen
« Reply #3 on: 31 January 2011, 23:39:06 »
Assuming you have an NCDC 201x, which I do, then I push the multi-function knob on the right hand size to clear those messages.
Alternatively, perhaps pushing the MAIN button would also clear it.
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 31 January 2011, 23:57:48 »
Thanks Steve.  :y
This might be a bit basic but, not steering wheel controls, the MID buttons on the wiper stalk.
« Reply #5 on: 01 February 2011, 00:02:23 »
Thanks Steve.  :y
If the OP has an Elite with a GID or CID then his controls aren't on the wiper stalk ;) (Mine are on the wheel, as I presume are his - select, up, down on one side, volume up, down and .. I forget on the other)
(My pre-facelift 2.5TD with a MID had controls on the wiper stalk)
zirk
  • Epping Forest
« Reply #6 on: 01 February 2011, 01:09:38 »
Thanks Steve.  :y
Well spotted, must learn to read the OP's Car details when coming home late.
 ;D
« Reply #7 on: 01 February 2011, 05:14:33 »
So it's showing the ice warning and continually flashing up when cleared? Think I had something similar if so but less persistent. Never got to the bottom of it.
I,m sure TB will respond but in the mean time is it worth resetting the head unit? Press and hold main and clear together for 6 seconds iirc.
Although not sure if it's a check control issue or if the head unit has any influence on it any way.  :-/
« Reply #8 on: 01 February 2011, 05:17:24 »
Was the temp hovering just above 3C. ?
SP_3.2
  • Leicester
« Reply #9 on: 01 February 2011, 09:49:40 »
Thanks for the tips everyone. Looking at the infor i did not put in that i have a new aftermarket unit fitted as my NCDC system is on the fizz and needs some parts replacing with the help of Mark should be up and runing again  soon . The new unit is
a Pioneer-AVH-3200bt.
It had the controls fitted for the steering wheel controls to work the system which works great ...just just not giving me any control over the CID. Think James pointed out that with out the NCDC the CID will not work  :-/ :-/. Was hoping there would be a way of still clearing the warnings somehow.  Not sure if any one has had the same prob with theres once they have changed the unit or found a way round this prob.
« Reply #10 on: 01 February 2011, 09:51:54 »
I beleive the only way is downgrade to a mid and stalk, and add some wiring  :'(
if you did this good money in the CID i reckon  :y
« Last Edit: 01 February 2011, 09:52:12 by jimbob »
SP_3.2
  • Leicester
« Reply #11 on: 01 February 2011, 10:04:31 »
Thanks Jimbob .... :y :y. Was thinking there was something that i could do but look,s like it,s a NO :'(.
« Reply #12 on: 01 February 2011, 10:06:26 »
Did you get the NCDC out then?
If so, pop it up as I have a spare CD carrier mechanism....or two.  :y
« Reply #13 on: 01 February 2011, 10:42:19 »
I'd gnaw someones arm off for a de-paired CID (or a CID & broken HU) ...  8-)
SP_3.2
  • Leicester
« Reply #14 on: 01 February 2011, 10:44:10 »
Did  ;D ;D ;D. The fitter told me that it took at good hour to get out, but no damage at all. :y :y.
If the normal time would be ok that would be great ...good to have it all sorted.. :y :y
