Author Topic: 2.5v6 heads vs 3.0  (Read 3311 times)
rickmv6
  • moreton  wirral
2.5v6 heads vs 3.0
« on: 29 January 2011, 21:07:24 »
hi i have had a problem with the cylinder heads on my mv6 3.0 the engine place  has said my heads are beyond repair so they have gave me a recon set where  i will use my existing cams.  problem is just noticed the heads have 2.5  etched into the side of each head.  does anybody know if these will still work.
« Last Edit: 29 January 2011, 21:22:12 by rickmv6 »
rickmv6
  • moreton  wirral
Re: 2.5v6 heads vs 3.0
« Reply #1 on: 29 January 2011, 21:54:48 »
according to haynes manual valves are same size for both engines its the cams which have a different height. but i will be using the 3 litre cams any way.  just not sure if i will loose power.
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #2 on: 29 January 2011, 21:58:07 »
A popular mod seems to be to replace 2.5 cams with 3.0 litre cams for a power increase. So it would obviously be a de-mod to go from 3.0 cams to 2.5 cams. But as you're keeping you 3.0 cams that won't be a problem.
What did the garage say is wrong with your heads? What is wrong with the heads?
TC and BnQ Trade holder.
« Reply #3 on: 29 January 2011, 22:01:25 »
I thought the 2.5 & 3.0 had different sized pistons and, thus, different size squish areas in the heads? (Which I'd think would create potential problems)
rickmv6
  • moreton  wirral
« Reply #4 on: 29 January 2011, 22:03:45 »
the heads where down on compression so took heads off. the outer half ring where water curculates was all blocked up when i cleaned them there was a big chunk of alloy that broke away. he said 2 much alloy would need to be welded in and he couldnt guarantee the work. so he got me these ones saying they where for the 3.0 litre
« Reply #5 on: 30 January 2011, 06:07:28 »
There was a member at Newent with 2.5 heads on a 3.0, so it will physically fit. Can't tell you the power output but I would not do it myself. It was frowned upon by those present as I recall. Probably due to reasons given above.
« Reply #6 on: 30 January 2011, 08:00:44 »
If he told you they were 3.0 heads and you have discovered for yourself that they are 2.5 heads, I would take that as a sign that he is incompetent/ dishonest, or both, and would take the car somewhere else. ;)
« Last Edit: 30 January 2011, 08:04:08 by albitz »
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #7 on: 30 January 2011, 08:19:15 »
i wouldnt go elsewhere, i would be straight back to the garage to demand that he puts 3.0l heads on  >:(
rickmv6
  • moreton  wirral
« Reply #8 on: 30 January 2011, 09:54:16 »
heads are not on engine yet they are still sitting in the kitchen  didnt want to fit them and find out it goes bang
« Reply #9 on: 30 January 2011, 10:19:26 »
I'd stick to 3.0l heads.  Given the hassle and expense of fitting them, may as well put the proper ones on.
The 3.0l also has sodium filled valves (exhaust only?)
MutantCav
  • Gainsborough
« Reply #10 on: 30 January 2011, 11:03:51 »
Well I have a pair of 3 ltr heads here mate, still on the car which runs perfectly...I would take the 2.5 heads back to the garage point out they are clearly not what you paid for and get your money back...
rickmv6
  • moreton  wirral
« Reply #11 on: 30 January 2011, 11:29:48 »
Is their anyway of checking weather thay have been labled the heads up wrong. one head had has code 90412231 and the other head has code 90412232. Not sure what this bloke has done with my original heads. thanks mate for the offer will speak to the garage and let you know.
sassanach
  • trowbridge
« Reply #12 on: 30 January 2011, 12:29:15 »
if i recall correctly, the 2.5 heads will raise the compression ratio to unacceptable levels.if you are convinced they are 2.5 heads then do not fit!!! :y
sassanach
  • trowbridge
« Reply #13 on: 30 January 2011, 12:33:35 »
just checked some 2.5 heads i have here, the numbers you have are for 2.5 heads, take them back!!
rickmv6
  • moreton  wirral
« Reply #14 on: 30 January 2011, 12:34:08 »
thanks for the help everyone will phone the garage tomorrow and see about a refund and thanks pete have sent you a reply. thanks all. rick.
