Author Topic: Busy day tomorrow.......  (Read 1149 times)
Taxi_Driver
« on: 21 January 2008, 19:49:46 »
I intend to change front and rear pads......rear pads are low....
I think the front are even lower  ::) I'm getting a loud squeak coming from the front at low speed....which stops as soon as i touch the brakes.....i did think wheel bearing......but as the squeak stops when touching the brakes.....im going for pads. They've done nearly 30k miles  ::)
Tho im not getting any pad warning on the mid.......so when I take that side wheel off, i'll take a pic of the sensor and post it, in case ive fitted it wrongly....and hence no warning.
Also Must remember to send Martin back his LPG lead......sorry for the delay  :-[
And If i get time.......do my tax return  ::) ;D
miggy
Re: Busy day tomorrow.......
« Reply #1 on: 21 January 2008, 19:51:31 »
Dont let tax be taxing..............the tinkers
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 21 January 2008, 19:55:10 »
You don't get a low pad warning until the sensor has been destroyed, daft idea by Vx that one >:(
Martin_1962
« Reply #3 on: 21 January 2008, 20:15:08 »
Just thinking about that yesterday, want to try really low changeover temperature as an experiment
Dazzler
« Reply #4 on: 21 January 2008, 20:18:25 »
« Reply #5 on: 21 January 2008, 20:33:19 »
Squealing that disappears when the brake is pressed is probably due to the pads building up a sharp edge which rubs on the disk. If the pads turn out to have plenty of meat on them, file a chamfer on the edges and they'll quieten down.
Hang on.. didn't you change your pads at Tidworth? :o
Taxi_Driver
« Reply #6 on: 21 January 2008, 21:04:12 »
That was rears.......which are down to 3-4mm , I changed the fronts before then  ::)
Paul M
  • Edinburgh
« Reply #7 on: 21 January 2008, 21:12:00 »
The sensor is designed to be replaced, it's cheap and cheerful (hence how it works by basically destroying itself) so no big deal really.
