Pages: 1 [2] 3  All   Go Down
Author Topic: Help! Brown Sludge in Water Reservoir!  (Read 5066 times)
Re: Help! Brown Sludge in Water Reservoir!
« Reply #15 on: 31 January 2011, 08:27:23 »
The garage i use sometimes said its a pig of a job cos to get to the oil cooler its in the centre of the V and you have to take off both heads not much change from 2k i think that what it cost his customer :( :(
Lol, I have seen that a few times. Miss diagnosis by the shitty independent who pulls the heads thinking its headgasket then finds its not fixed it.
Of course, they dont come clean, they just bill the poor unknowing individual who trusted them in the first place.
Oil cooler is a 3 hour job start to finsh plus frequent flushing at various intervals there of
richardirv
  • Leeds, West Yorkshire
    • Omega 2.6 MV6 2002
« Reply #16 on: 31 January 2011, 08:37:29 »
Anyone have access to GM prices?
I found a Cooler online for £133, not sure if its definatly genuine though?
http://www.courtenaysport.co.uk/buy-online/shop-by-category/parts/oil-cooler-v6-all-non-turbo-models/prod_668.html
IIRCC the kit is about £105+VAT :-/ :-/
Do you think the one in the link will be genuine then or spurious?
« Reply #17 on: 31 January 2011, 08:42:23 »
Don't know if that's even everything you need TBH... I've never had to do one <touches wood!>
Looks promising with genuine GM sealant but why not contact andyc and see if he can give you a better price?
richardirv
« Reply #18 on: 31 January 2011, 08:48:20 »
Ok, just looked at his profile, didn't realise he worked at vx.
I have one friend to see locally too who may be able to get vx trade price so I will see which is best
Cheers
« Reply #19 on: 31 January 2011, 08:58:38 »
Given that it includes the sealent and metal oil cooler pipe O rings, its a good price.
You do also need the coolant bridge dowty washers though.
richardirv
« Reply #20 on: 31 January 2011, 09:23:21 »
Ok cheers, I have pm'd andyc, see what he can do  :y
« Last Edit: 31 January 2011, 09:23:45 by richardirv »
« Reply #21 on: 31 January 2011, 09:28:19 »
How about asking Marky Mark via Guy?
richardirv
« Reply #22 on: 31 January 2011, 09:39:59 »
Do you mean for the parts? Or to do the job?
Assuming you mean parts, I had not thought, does mark have trade card then?
« Reply #23 on: 31 January 2011, 10:03:05 »
I meant to do the job, but I'm sure he'd be able to get you the parts.
richardirv
« Reply #24 on: 31 January 2011, 10:06:01 »
Yeah I had thought about asking Mark but decided against it as I'd have to drive the car 55 miles to do so & wan't sure if that was a good idea  :-/
« Last Edit: 31 January 2011, 10:06:49 by richardirv »
« Reply #25 on: 31 January 2011, 10:15:55 »
... I'd have to drive the car 55 miles to do so &  ....
Ah! I thought you were closer.
richardirv
« Reply #26 on: 31 January 2011, 10:20:41 »
Unfortunatly not, andyc has kindly just given me a quote.
I hope he doesn't mind be posting on here, don't see why not. It apears that Lazy is right regards not having all I will need with the kit I found online. But the kit is indeed cheaper online (if its genuine)
Oil Cooler Kit £146.88
Banjo Seals 4 @ £0.58 each
Cooler Cover Sealant £10.00
Inlet Manifold Bridge Lower Gaskets, 2 @ £14.64 each
Inlet Manifold Bridge Upper Gaskets, 3 @ £12.16 each
Plenium Seal Kit £13.73
Antifreeze, 5ltr £14.04
Engine Oil 10w40 Semi Syn 5ltr £13.92
Oil Filter £3.88
Postage £8.28
All prices include VAT @ 20%
« Last Edit: 31 January 2011, 10:21:34 by richardirv »
« Reply #27 on: 31 January 2011, 10:43:51 »
even I can do an oil cooler, only extra tool worth getting is 19" crowsfoot for the oil cooler pipes at the filter end. Don't bend the pipes above the cooler!
Are you sure its a 19 inch spanner Tunnie ? Istr it was a wee bit smaller than that  :-/ :D ;D ::)
Cause my one was huge  :D  ;D
Sorry yes, its 19mm crowsfoot. Its really a must for the oil cooler job without mangling the nut
« Reply #28 on: 31 January 2011, 10:50:17 »
Oil Filter £3.88
Postage £8.28
You won't need these, you can re use the originals ;)
richardirv
« Reply #29 on: 31 January 2011, 10:52:55 »
Oil Filter £3.88
Postage £8.28
Oh good, thats a little better on the wallet!  :y
Pages: 1 [2] 3  All   Go Up
