Pages: [1] 2 3  All   Go Down
Author Topic: Help! Brown Sludge in Water Reservoir!  (Read 4944 times)
richardirv
  • Leeds, West Yorkshire
    • Omega 2.6 MV6 2002
« on: 30 January 2011, 16:50:31 »
Went out last night to top up my washer bottle and decided to check my water/oil levels too, glad I did.
Its just brown sludge, now my first panic thought was head gasket but the oil on the dip stick is ok, very low but ok.
Am I right that this is looking like an Oil Cooler problem or failure?
I topped my oil up and flushed out some of the sludge and topped up with water as I needed to use the car last night. (Peter Kay Live  :y)
The car drives fine, no mis fires or anything.
Is it wise to drive short trips to work etc before its fixed? Guessing not really!  :'(
Re: Help! Brown Sludge in Water Reservoir!
« Reply #1 on: 30 January 2011, 16:55:39 »
Does sound like oil cooler and I wouldn't use the car until its repaired. The worst part of the job is getting the oil/sludge out of the cooling system and the more you use the car the more crap gets into the cooling system :(
« Reply #2 on: 30 January 2011, 16:57:01 »
deffo sounds like oil cooler.......and do not drive it until replaced
richardirv
« Reply #3 on: 30 January 2011, 16:57:27 »
Fair play, I will have to use the Yaris  >:(
What do you rekon i'm lookin at for new oil cooler and fitting?
chrispin
« Reply #4 on: 30 January 2011, 17:51:13 »
The garage i use sometimes said its a pig of a job cos to get to the oil cooler its in the centre of the V and you have to take off both heads not much change from 2k i think that what it cost his customer :( :(
« Reply #5 on: 30 January 2011, 17:59:20 »
You need to find a new garage then! :o :o
I know members who have done it in a supermarket car park! ;) :y
richardirv
« Reply #6 on: 30 January 2011, 18:18:49 »
Anyone have access to GM prices?
I found a Cooler online for £133, not sure if its definatly genuine though?
http://www.courtenaysport.co.uk/buy-online/shop-by-category/parts/oil-cooler-v6-all-non-turbo-models/prod_668.html
« Reply #7 on: 30 January 2011, 18:21:47 »
IIRCC the kit is about £105+VAT :-/ :-/
chrispin
« Reply #8 on: 30 January 2011, 18:24:57 »
Now thats a step by step worth reading  8-)
« Reply #9 on: 30 January 2011, 18:29:35 »
Yeah, thanks Mr Morrison ;D
« Reply #10 on: 30 January 2011, 19:47:10 »
Daz did an oil cooler at Newent & he definitely left both heads on.
I think he was on his 8th Stella!  ::)  ::)  ;D  ;D  ;D
Bent valve
« Reply #11 on: 30 January 2011, 19:52:19 »
Robbing, lying b*stards!
« Reply #12 on: 30 January 2011, 21:26:45 »
even I can do an oil cooler, only extra tool worth getting is 19" crowsfoot for the oil cooler pipes at the filter end. Don't bend the pipes above the cooler!
« Reply #13 on: 30 January 2011, 23:41:43 »
2k? For 3 or 4 hours work? FFS ! Go round there and get your money back.
« Reply #14 on: 31 January 2011, 00:38:31 »
Are you sure its a 19 inch spanner Tunnie ? Istr it was a wee bit smaller than that  :-/ :D ;D ::)
Pages: [1] 2 3  All   Go Up
