Pages: 1 2 [3]  All   Go Down
Author Topic: Help! Brown Sludge in Water Reservoir!  (Read 5065 times)
Re: Help! Brown Sludge in Water Reservoir!
« Reply #30 on: 31 January 2011, 10:55:57 »
... I'd have to drive the car 55 miles to do so &  ....
Ah! I thought you were closer.
Unfortunatly not, andyc has kindly just given me a quote.
I hope he doesn't mind be posting on here, don't see why not. It apears that Lazy is right regards not having all I will need with the kit I found online. But the kit is indeed cheaper online (if its genuine)
Oil Cooler Kit £146.88
Banjo Seals 4 @ £0.58 each
Cooler Cover Sealant £10.00
Inlet Manifold Bridge Lower Gaskets, 2 @ £14.64 each
Inlet Manifold Bridge Upper Gaskets, 3 @ £12.16 each
Plenium Seal Kit £13.73
Antifreeze, 5ltr £14.04
Engine Oil 10w40 Semi Syn 5ltr £13.92
Oil Filter £3.88
Postage £8.28
All prices include VAT @ 20%
You won't need these, you can re use the originals ;)
Oh good, thats a little better on the wallet!  :y
Only thing i don't see there are replacement bango bolts, iiic they don't come with the oil cooler kit....
richardirv
  • Leeds, West Yorkshire
    • Omega 2.6 MV6 2002
« Reply #31 on: 31 January 2011, 11:07:02 »
Oil Filter £3.88
Postage £8.28
Ok, Cheers
« Reply #32 on: 31 January 2011, 11:08:47 »
Oil Filter £3.88
Postage £8.28
I've never had one snap but I have seen on the forum people that have had the misfortune.
« Reply #33 on: 31 January 2011, 17:06:01 »
I snapped one on TB1, luckily a nail across the bits of the top of the bolt managed to rotate it back.
Officially they are once only use i belive....
« Reply #34 on: 31 January 2011, 17:32:24 »
I'm surprised because they aren't torqued very tight
« Reply #35 on: 31 January 2011, 18:30:33 »
nope
« Reply #36 on: 31 January 2011, 19:25:09 »
I've broken 2  :-[
I suspect in both cases, it was weakened whilst undoing, as neither set the torque wrench off
« Reply #37 on: 31 January 2011, 19:34:03 »
I've broken 2  :-[
maybe you shouldn't be blindly relying on the halo'd torque wrench & use a bit of feel when tightening some things  :-/ :-/  ::)
« Reply #38 on: 31 January 2011, 22:07:44 »
nope
Well seeing how easily i sheared one, think i would personally recommend new ones for such a job. Minimal cost for a one off task?
« Reply #39 on: 31 January 2011, 22:10:29 »
nope
Someone else must have already had a go on it... No way you could have sheared it without help :-X :-X Or did you have a 4' scaffold pole on the end of the wrench ::) ::) :P :P
« Reply #40 on: 31 January 2011, 22:15:48 »
.... Or did you have a 4' scaffold pole on the end of the wrench ::) ::) :P :P
I can vouch that 50 stone/3 blokes hanging off said scaff pole are able to shear a 3/4" T-bar, an 1" - 3/4" adapter and a Britool 3/4" ratchet  ::) ::) ::) ::)
V6 CDX-er
  • Sheffield
« Reply #41 on: 14 February 2011, 03:08:19 »
Oil Filter £3.88
break me! Will this bloody car ever stop costing me a fortune? I haven't even driven it 25 miles yet, and already it's cost me 75% as much in parts as it did to buy the bloody thing!  >:(
And there was me thinking what could possibly go wrong with an Aussie / German designed, and German built motor? In terms of cost per mile, this is already costing me more than the Land Rover, (high), and even more than the bloody TVR, a motor which has so far cost a medium sized countrys GDP to run.
Once this Omega is fixed, I'm not selling the bastard, not ever. It's cost me too much bloody money! This dam thing has had my money, my blood, my sweat and nearly my tears. It's a good job that I'm not as easily angered as I was in my late teens / early twentys, otherwise there would now be a nice size ten bootprint in each door!  :'(
Another £155 in parts and several nights in the garage? The wifes going to hit the roof.
Hannah Judes Dad
    • the misses round the bend
« Reply #42 on: 14 February 2011, 11:00:58 »
Oil Filter £3.88
Once this Omega is fixed, I'm not selling the blank, not ever. It's cost me too much bloody money! This dam thing has had my money, my blood, my sweat and nearly my tears. It's a good job that I'm not as easily angered as I was in my late teens / early twentys, otherwise there would now be a nice size ten bootprint in each door!  :'(
At least you know it will not need doing again for a long time and you will know that the job was done properly.
I know that some other halves don't understand that jobs need doing but is it not for the greater good of your car? I know that there are plenty of things that will need doing on my car but as it was £350 two years ago it doesn't take much to work out that things will need to be done through gritted teeth and an emptying wallet,it's the nature of the beast.
« Reply #43 on: 14 February 2011, 11:57:32 »
nope
Since an old tread is dragged up, i'll defend myself and say it never even got to the torque wrench stage, it is was about 2/3's in, and the top just sheared off.  :o
V6 CDX-er - Oil cooler is once in a cars life job, the problem is removing the oil be prepared for about 20 million of them to start it running clean again!
Pages: 1 2 [3]  All   Go Up
