Author Topic: po141 code  (Read 1346 times)
unlucky mark mv6
  • tipton,west mids
po141 code
« on: 19 February 2011, 22:21:48 »
As i have code po141,it says sensor 2 on bank 1 heater circuit malfunction,am i right in saying that the lamba is knackered,or is it something else,possibly vacuum leak,faulty injector etc,or even blowing manifold. :-/
Re: po141 code
« Reply #1 on: 19 February 2011, 22:24:43 »
It is sensing an open circuit in the heater line ... all lambda probes are heated.
Either ... heater has failed = new lambda sensor or a wire is off/damaged
unlucky mark mv6
  • tipton,west mids
Re: po141 code
« Reply #2 on: 19 February 2011, 22:26:49 »
Thanks entwood,will check it out tomoz then. :y
unlucky mark mv6
  • tipton,west mids
Re: po141 code
« Reply #3 on: 19 February 2011, 22:32:15 »
Also where is this sensor located,would it be the bottom one on the drivers side. :y
Re: po141 code
« Reply #4 on: 19 February 2011, 22:33:10 »
unlucky mark mv6
  • tipton,west mids
Re: po141 code
« Reply #5 on: 19 February 2011, 23:21:51 »
Thanks rob :y
