Author Topic: removing rear shocks heeeelp!  (Read 1551 times)
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« on: 07 March 2011, 13:15:14 »
hi all, i am in the middle of replacing my rear shocks and have hit a snag the bottom of the shock the sleeve is jammed in there anyone have any tips on how to get it out? many thanks for speedy replies!!
Warning: Dates in Calendar are closer than they appear.
Varche
  • middle of Andalucia
    • Golf Estate
Re: removing rear shocks heeeelp!
« Reply #1 on: 07 March 2011, 13:20:59 »
Plus Gas penetrating fluid.
Then gentle taps  on the bottom of the shocker alternating side to side with a rubber mallet or a hammer and a lump of wood.
« Reply #2 on: 07 March 2011, 13:30:53 »
I did mine last week, estate are a bit different
i pulled the shock off leaving the little metal 'tube' stuck in the car.
I covered this in penetrating fluid, then a few bashes up and down with a hammer and it prised out no problems.
mrgreen
  • Salzburg/austria
« Reply #3 on: 07 March 2011, 13:30:57 »
thanks varche i don't have plus gas hopefulyy wd40 will do the trick cheers,
Rich
mrgreen
  • Salzburg/austria
« Reply #4 on: 07 March 2011, 13:32:29 »
i've been bashing my shock eye with a cold chisel and hammer and it still won't move will try the side to side approach!
Boracic
  • Dartford Kent
« Reply #5 on: 07 March 2011, 16:17:02 »
I tapped the hub around the mount then wiggled the shock from side to side, didn’t even use wd40
mrgreen
  • Salzburg/austria
« Reply #6 on: 07 March 2011, 16:25:51 »
finally got it off i heated it with a hot air gun it was still resisting but finally came off, probably didn't help that it was only three degrees out today!
Agemo
  • Cleethorpes
  • Insignia
« Reply #7 on: 07 March 2011, 17:00:31 »
Must have been awkward working with three women singers doing "When will I see  you again" in your ears  ::)
Glad you got them sorted, never had a problem, must be lucky.
« Last Edit: 07 March 2011, 17:01:10 by Agemo »
