Author Topic: factory fitted lpg  (Read 1607 times)
gerry c
  • derry
factory fitted lpg
« on: 19 March 2011, 02:46:48 »
i have a 2003 2.2 lpg/petrol omega the previous owner told me the lpg was factory fitted. did vauxhall do this as an extra, does anyone else have it fitted??
 as i have no history with the car i dont know who did it :(
do lpg tanks have to go through an inspection every few years?? dont want to be driving around with a bomb in my boot even tho it goes like a bomb lol.
Re: factory fitted lpg
« Reply #1 on: 19 March 2011, 09:06:43 »
IIRC there were no Omega's with "Factory Fitted" LPG. It will be an aftermarket system in some form... Can you have a look around for the kit brand?
In answer to your question about tanks... They are pressure certified for 10 years when new :y Unfortunately it'll probably be cheaper to have a new tank fitted than to get the existing one certified ;)
« Reply #2 on: 19 March 2011, 09:37:46 »
I thought some "factory fit" dual fuel branded Vauxhalls had Necam Koltec LPG kit?
Gerry - It was never technically "factory fit" it was retro fitted afterwards, but before it was delivered.
No real maintenance on LPG apart from the fuel filter, and as LD says, tanks pressure tested every 10 years  :y
« Reply #3 on: 19 March 2011, 10:42:00 »
Yep, they did... But I don't think the Omega was ever available as Dual Fuel from Vauxhall in the UK... I might be wrong though ;)
Gerry, easiest way to tell is to follow this link to try and identify if it is a necam system fitted :y
« Reply #4 on: 19 March 2011, 10:44:17 »
The only Dual Fuel 'factory fit' lpg car I've been sat in was an Astra. The gas & petrol both shared the same original dash fuel gauge.  :-/
« Reply #5 on: 19 March 2011, 10:56:17 »
They definitely did Astra and Vectra. I think they also did Corsa but don't recall ever hearing of an Omega :-/ But yes, I think it did use the fuel gauge on the dash for both fuels
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #6 on: 19 March 2011, 12:38:06 »
I think mine was done from new, I looked into it and was told a Koltec kit , branded Opel, was suplied with the car and VX dealers used the nearest installer to have it fitted. Mine shares the petrol fuel gauge.
« Reply #7 on: 19 March 2011, 20:50:50 »
I stand corrected then ;) It's the first Omega I've heard of converted from new, and also the first V6 too :y
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #8 on: 19 March 2011, 21:06:55 »
Tunnie, just a quick one on your comment.... ref the fuel filter, is that a LPG filter or petrol filter? Sorry if thats a daft question but this is my first car with LPG and know nothing about these systems.
Cheers  :y
AKA - Mr Bracket
« Reply #9 on: 19 March 2011, 21:22:47 »
LPG filter, as thats the one thats used :)
Offically its 10k, but thats cause most systems are polish, and their LPG is not as clean as ours.
Every 30k or so its worth replacing  :y
« Reply #10 on: 19 March 2011, 21:47:27 »
AFAIK, only the prefacelift 2.0l was offered with a duel fuel option...
blackviper90210
« Reply #11 on: 19 March 2011, 22:33:23 »
Cheers for that Tunnie  :y
Will look up the system type I have and see if it needs doing!
Thanks again.
AKA - Mr Bracket
« Reply #12 on: 19 March 2011, 22:52:37 »
... with a duel ....
Pistols at dawn or on guard???  ::) ::)  ::) ::) ::) ::) ::)  ;)
« Last Edit: 19 March 2011, 22:53:33 by Andy_B »
