Author Topic: haunted or what??  (Read 1078 times)
smurfdjman
  • Inchinnan,Renfrew,Scotland
haunted or what??
« on: 27 March 2011, 20:10:09 »
to put you in the picture, i bought my Omega 2 weeeks ago and it has had minor problems that i have rectified some, when i got the car the key fob didnt work ,but martin Imber has fixed that one , the other problem was that the speedo didnt work and that the ABS/TC was constantly on, so i contacted the forum and had believed that the ECU is faulty. so heres my problem , i took the car, wife and child out for a run today went 100 mile round trip and intermitantly the speedo started working and the ABS/TC light went out
any ideas!!!
Re: haunted or what??
« Reply #1 on: 27 March 2011, 20:16:24 »
Not at all uncommon.... the "failure" of the ABS ECU is generally intermittent at first ... mine would work for 5 minutes, then fail for 15 then start working again .. but over time it steadily got worse.... :(
As the failure is basically a wire coming adrift internally my guess is that it is sort of "heat" related as the connection "makes and breaks" and the conformal coating temperature will affect this.
One thing I do know .. it steadily gets worse until it goes completely !!
smurfdjman
« Reply #2 on: 27 March 2011, 20:21:24 »
hi Entwood
thanks for your reply but ,the thing that puzzles me is that the speedo had never worked when i got the car and the ABS/TC lights were always on.
could this mean that it could be a faulty sensors instead of the ECU
« Reply #3 on: 27 March 2011, 20:25:35 »
ABS ECU for certain, perhaps it just got nice and warm on a long run in warmish weather, enough for the electrickery to start to flow again ...  did you notice any change to the power steering ??? When mine was just about to fail completely the PS also became intermittent... and that was NOT at all  nice .. :(
£130 to fix it was a very good investment IMHO :)
« Last Edit: 27 March 2011, 20:26:07 by entwood »
smurfdjman
« Reply #4 on: 27 March 2011, 20:32:23 »
no i dont think so!
how long can idrive the car with this problem?
another Query what should i be paying for coolant and how much do i need to fill my tank , as the coolant level warning is on and im going to try and change the coolant first???
p.s you guys on this forum have been great!!
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #5 on: 27 March 2011, 22:57:20 »
no i dont think so!
some coolant is lost when changing ABS ECU as pipe has to come off. Might be best to change after that, or at least, use cheap stuff/and or cleaner, then when abs ecu replaced, use vx red coolant.  Someone will say otherwise, but about 9 litre capacity of coolant iirc. Half and half coolant/water. 5 litres of Vx red coolant is £14.09 retail and £11.70 tradeclub at dealers.
p.s. check coolant level, if ok and warning still on, probably a dodgy sensor.
« Last Edit: 27 March 2011, 23:01:26 by geoffr70 »
TC and BnQ Trade holder.
