Author Topic: Omega estate rear wiper arm and blade  (Read 1886 times)
wadeyblue
  • Fife Scotland
« on: 28 March 2011, 19:06:05 »
Hi All
Does anyone know if any othe vehicle rear wiper arm and blade will fit my omega estate.
My original arm is very rusty now and I like the look of the Astra/ Signum rear arm assembly but I tried one from a Signum and it is too big for the omega spline.
Cheers
wadeyblue
MV6Matt
  • London
    • No car since 2022....
Re: Omega estate rear wiper arm and blade
« Reply #1 on: 28 March 2011, 19:35:31 »
HAve you tried a vectra one (or would it be same size)?
What about the Astra?
I use one from the Ford Focus - got it off ebay from a wiper store.
Alternatively, get a new arm and blade from Vx
None of the wiper springs are really strong enough and I haven't found a blade that can properly cope with the curve of the rear screen.
HTH
Matthew :y
(thanks Ian)
« Reply #2 on: 28 March 2011, 20:03:21 »
Hi All
Cheers
wadeyblue
why not just use an Omega estate wiper?  :-? :-? :-? The whole arm, blade & spindle cover was around £30 for an Astra G hatch.
wadeyblue
  • Fife Scotland
« Reply #3 on: 28 March 2011, 20:07:01 »
Prefer the look of the thicker enclosed arms, would like a change from the skinny steel omega arm.
« Reply #4 on: 28 March 2011, 20:12:01 »
Ah! I see, like the Astra G's  :y :y :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #5 on: 29 March 2011, 06:05:46 »
HTH
Matthew :y
For the blade you MUST use the original GM part which is readily curved to fit the window properly  :y None of the aftermarket ones has this shape, so it's original only.
bigegg
  • Leeds
    • MV6 RIP - Lexus GS300 '99
« Reply #6 on: 29 March 2011, 08:18:58 »
vectra arm is about an inch shorter.
has the same spline fitting .
interesting about the blade shape.
explains why my back window doesn't wipe properly.
« Last Edit: 29 March 2011, 08:19:31 by bigegg »
Carpe Incendium
MV6Matt
  • London
« Reply #7 on: 29 March 2011, 10:35:08 »
HTH
Matthew :y
[/highlight]
I don't agree - the GM one does not clean it properly -the top of the blade lifts off the screen because of the curve of the glass.
Stand beside your vehicle and watch it lift off the glass as it wipes.
As I said in my original post - I've not come across any wiper arm/blade that will sweep 100% in contact with the glass.
I've gone for a different look knowing it wont work - but I might try the Astra 'G' next!
Matthew
« Last Edit: 29 March 2011, 10:35:55 by MV6Matt »
(thanks Ian)
« Reply #8 on: 29 March 2011, 10:53:21 »
Both of our estates clean perfectly - New GM arms and New GM Blades.
The time they dont, is if the screens get too dirty, but kept clean (using just the wiper) then they work fine in our experience.
As they get old, then they start missing bits.
« Last Edit: 29 March 2011, 10:53:43 by jimbob »
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #9 on: 29 March 2011, 10:57:53 »
HTH
Matthew :y
[/highlight]
Matthew
That's exactly my point! Are you sure you got the right blade for rear screen for Omega? It is a special blade and if you even look at it when you open the box you'll see it's almost like a boomerang, curved well enough to clean the whole area.
I've had now two estates and both have had the problem not sweeping the whole area when I have got them but both times the cure has been to use the genuine GM blade. And, as I said, it really is curved as new.
MV6Matt
  • London
« Reply #10 on: 29 March 2011, 17:14:05 »
Always got my replacement blades from Vaux - never made a bit of difference!
(thanks Ian)
DJ Pete
  • Chelmsford, Essex.
« Reply #11 on: 30 March 2011, 16:19:22 »
My replacement wiper from Vauxhall made no difference either.
