Author Topic: mv6 auto alarm problems  (Read 1324 times)
Spikeqed
  • brighton
« on: 25 March 2011, 20:26:03 »
Hello this is my first post, i have a mv6 auto estate 3L 2000 model. i am still having alarm going off for no reason. i have allready taken off power sounder, and bonnet sensor, but its still doing it.
i am having to leave it unlocked due to several notes on my windscreen from heighbours. any help or advice would most appreciated. Spikeqed.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: mv6 auto alarm problems
« Reply #1 on: 25 March 2011, 20:30:09 »
when you get out(with keys in hand) open rear door...push drivers door button down, then close back door. this will stop it activating the alarm. hth.
« Reply #2 on: 25 March 2011, 20:37:05 »
other thing to try is closing the internal vents / removing dangling air fresheners etc  or diasabling the ultrasonics (running man button)
best bet is to get plugged into a decent diag computer and read the alarm log for what is triggering it.
The Red Baron
« Reply #3 on: 25 March 2011, 20:40:47 »
you beat me too it there. :D
Spikeqed
  • brighton
« Reply #4 on: 27 March 2011, 17:33:23 »
Hi everybody. Thanks very much for all your advice. I have doing the back door method and then simply locking drivers door with the key, and then opening it with the keyfob . no lights flash when locking with the key. so i presume it is not arming itself ?.seems to be a lot better only went off once in last 24hrs but it was surrounded by 30 very noisy mods and  mopeds.I will try all your other surggestions  ,then let you know. Many Many Thanks SpiKeqed.!!!
Spikeqed
  • brighton
« Reply #5 on: 08 April 2011, 20:18:51 »
Hi everybody ,from Spikeqed. just a quick update about my alarm nightmares. well opening the back door and pushing driver door lock down,seems to the one. it has only gone off a couple of times since. I just wanted to say  Thanks for all your help youve all been Great. SpiKe.
« Reply #6 on: 08 April 2011, 23:09:27 »
IF the alarm is still going off when you just use the door buttons, you have a faulty powersounder, as the alarm isnt set.
Its under the drivers side wiper scuttle, PLEASE unplug / and remove it, these go up in flames when they go faulty, and may take the whole car with it, we have seen it a lot of times, including on my own driveway!
