Pages: [1] 2 3  All   Go Down
Author Topic: Replacing brake light  (Read 5218 times)
SMD
  • London
    • :( nowt
« on: 03 August 2010, 00:58:34 »
My right brake light bulb needs replacing and I know stuff like this is a doddle but wanted to know if there was anything tricky about doing it. Do I just pull the connectors out and undo the screws/nuts to get to the bulb ? :-[
« Last Edit: 03 August 2010, 00:59:56 by SMD »
Re: Replacing brake light
« Reply #1 on: 03 August 2010, 01:30:21 »
Open boot!  ;)
On the back of the light unit, you'll see a black 'housing' that hold all the lamps/bulbs. Somewhere towards the top is a tab (can't remember exactly what it looks like & I'm not going outside to look  ::)) that you press which will allow the whole black bit to come out. Your brake light lamp/bulb is the one with twin filaments ie stop lamp & tail light. Make sure you fit the lamp in the correct way around. In theory the two pins on the side on the lamp which are at different heights should stop you from fitting it incorrectly but ..... you can fit it wrong if you force it.  ::)  ;)
SMD
  • London
    • :( nowt
« Reply #2 on: 03 August 2010, 10:39:01 »
Thanks Andy
SMD
  • London
    • :( nowt
« Reply #3 on: 06 August 2010, 11:29:14 »
So I replaced my brake light bulb just now, how hard could it be, right? 2 mins down the road I got a message that read "headlamp tail light" and intermittent "brake light" message.
When I got home I got the boy to step on the brakes while I checked the lights. They work fine but when I turn the headlamps on the third brake light constantly stays on and acts as a tail light.
Whats going on here? I wonder how any OOFers it will take to fix a light bulb.  ;D
« Reply #4 on: 06 August 2010, 11:39:19 »
.... I got a message that read "headlamp tail light"  ....
That suggests that you now have a lamp out somewhere. You had 2 tail lights on each side? CAn't say why you now have a constant high level brake light though  :-/ Try taking your new lamp out & see what happens.  :-/
« Reply #5 on: 06 August 2010, 11:42:05 »
I had something vaguely silimar in an astra 15 years ago
new bulb fitted  brake / tail
whenever you braked, headlights came on.
iirc the fix was to turn the bulb around  :y
but it was a long time ago...
SMD
  • London
    • :( nowt
« Reply #6 on: 06 August 2010, 11:52:35 »
Andy - I checked all the lamps. They all work. 2 tails lights? I'll try taking the bulb out to see what that does.
Jim, turn the bulb around? Do you mean turn that buld 180 degrees and refit?
« Reply #7 on: 06 August 2010, 12:10:01 »
Yup, no guarantee's but worth a try
SMD
  • London
    • :( nowt
« Reply #8 on: 06 August 2010, 12:30:26 »
Turned the bulb as jimbob said, no change.
Took the new bulb out and the 3rd brake doesn't come on with the headlamps but put it back in and the 3rd brake light stay on as a tail light.
SMD
  • London
    • :( nowt
« Reply #9 on: 06 August 2010, 15:07:08 »
Another update
I just noticed when I press the brake pedal the front right headlamp also flashes.  :-?  This is probably what the "headlamp tail light" warning was about.
Whats going on?
neilr
  • Barnet, Herts
« Reply #10 on: 06 August 2010, 15:46:18 »
I would think you have an earth issue. Check lamp holder for corrosion and  try a different bulb some cheap bulbs give problems try a good brand ie lucas phillips osram etc. I had probs with n/s/r stop lamp bulb worked intermittantly bulb change problem solved.
GaryBC
  • Egham, Surrey
« Reply #11 on: 06 August 2010, 15:50:56 »
Back in "The Old Days" (ie when wires connected directly between switches and bulbs without any electronickery involved) a snag like this usually pointed towards a bad earth somewhere.
As a result the return current found an alternate path to earth - through another bulb somewhere, thus causing it to light up.
SMD
  • London
    • :( nowt
« Reply #12 on: 06 August 2010, 15:52:18 »
Lamp holder is in good nick, no corrosion. The bulbs are from Halfrauds. Should I get some bulbs from VX?
Gary, how can I fix this earth issue?
« Last Edit: 06 August 2010, 15:53:34 by SMD »
« Reply #13 on: 06 August 2010, 21:48:30 »
Think you have 2 issues
1) Bad earth somewhere
2) Dont use Halfords bulbs - they will work ok but not clear MID fault message - use Vx or Ring bulbs.
SMD
  • London
    • :( nowt
« Reply #14 on: 06 August 2010, 22:33:22 »
I will buy GM bulbs tomorrow and hoping that should be enough to solve my issues.
How can I overcome a bad earth?
Pages: [1] 2 3  All   Go Up
