Author Topic: thermostat etc help  (Read 1365 times)
thermostat etc help
« on: 21 April 2011, 15:31:08 »
Just nipped out to do her thermostat and cam cover gaskets...
and Ive been met by this in the V.
not sure if Ive an oil cooler leak, plus somethings going on with the coolant bridge.
What do I need to order to sort the bridge out?
Im about to check the wetness for oil, to see if I need to do the oil cooler as well.
Re: thermostat etc help
« Reply #1 on: 21 April 2011, 15:37:21 »
Looks to be just coolant thats run through oil.
thats one bit less...
Just the bridge to sort
explains where the tiny coolant loss was anyway.
Anyone know what I need?
cheers
« Reply #2 on: 21 April 2011, 15:39:44 »
4 x dowty type seals - plus 2 new through bolts as old ones can break!!  HTH mate
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #3 on: 21 April 2011, 15:44:51 »
cheers
A ride to Nottingham. ;D
TuBy's new whipping boy.
« Reply #4 on: 21 April 2011, 15:49:40 »
cheers, washers in stock, bolts on order
so ill remove em and see if I need the bolts.
« Reply #5 on: 21 April 2011, 15:54:15 »
bolts are fine :)
field trip to Vx....
« Reply #6 on: 21 April 2011, 17:49:59 »
I must be lucky, i've never had a banjo bolt snap yet ;)
« Reply #7 on: 21 April 2011, 19:15:48 »
Well thats the thermostat done....
And a big sense of achievement for me  :D
Camcovers in the morning  :y
« Reply #8 on: 21 April 2011, 19:29:09 »
Nor have I but have read on here that it can happen - still got a couple of newuns  ;)
« Reply #9 on: 21 April 2011, 19:36:58 »
cheers
Im not that bad any more, can tackle a lot myself.
B-Bolt - my 1st ever, awkward, but not too bad in or out, flexi ended ratchet spanner did the job nicely.
Didnt even need to sort the thermostat bolts, my pattern thermostat was genuine old style GM, with the GM logo ground off  ;D
Just praying it will be watertight when it goes back together  :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #10 on: 21 April 2011, 19:47:02 »
cheers
Good on you mate.
I'm going the other way nowadays, I just let the gnome do it all.
As they say "No use keeping a dog and barking yourself." ;D ;D
« Reply #11 on: 22 April 2011, 13:27:30 »
Had it all finished and back together by 10:30 this morning, been out and about in it and all seems fine  :y
