Author Topic: Aircon not so cold  (Read 2979 times)
SMD
  • London
    • :( nowt
Aircon not so cold
« on: 22 April 2011, 20:57:59 »
Aircon was regassed two weeks ago and I'm quite disappointed with the performance. It was 25 degrees today and on LO with maximum fan speed it was not very cold. My last Omega preface was freezing cold with the a/c (obviously) on but with the fan off.
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Aircon not so cold
« Reply #1 on: 22 April 2011, 21:00:18 »
Possible Slow leak maybe?  :-?
SMD
  • London
    • :( nowt
« Reply #2 on: 22 April 2011, 21:10:08 »
Guy that done the regas said there were no leaks
Stallion
  • Romford
« Reply #3 on: 22 April 2011, 21:13:54 »
me and damon80 were on the same boat, vacum test showed no leaks but it did?? was leaking through the actual valve they use to fill up the ac.  :(
« Reply #4 on: 22 April 2011, 21:19:07 »
He'd have to say that cos the law says that you can't fill a system when you know there's a leak. Huge fines for doing so.
Stallion
  • Romford
« Reply #5 on: 22 April 2011, 21:21:43 »
 :y :y :y :y
SMD
  • London
    • :( nowt
« Reply #6 on: 22 April 2011, 21:23:19 »
So would a slow leak affect the a/c blowing cold?
I recall him saying the was 50g of gas still in the system and it was pressurised. Anyway whats the next port of call?
Stallion
  • Romford
« Reply #7 on: 22 April 2011, 21:30:15 »
i dont know if it vary's from car to car, but i remeber putting in 90+gms in there?? if he used dye with the regas, then go back to the guy! >:(
but before anything just check the valve, open the cap (little) and see if you can hear it leaking..
SMD
  • London
    • :( nowt
« Reply #8 on: 22 April 2011, 21:32:38 »
The system holds 950g but there was still 50g in the system before regassing. He didnt use dye.
« Reply #9 on: 22 April 2011, 21:35:59 »
I would agree with Stallion - take it back and have it checked out. :y
Stallion
  • Romford
« Reply #10 on: 22 April 2011, 21:36:48 »
my bad, meant 950gms!  :y
« Last Edit: 22 April 2011, 21:38:12 by Stallion »
SMD
  • London
    • :( nowt
« Reply #11 on: 22 April 2011, 21:45:25 »
It was a mobile fitter and my concern is if I call him he will tell me there were no leaks (that is if he remembers).
He did tell me before turning up that if the system could not be regassed for any reason, I would need to pay him £20 for his time so if there was a problem he would have taken the easy money (I would anyway). He works for a franchise called AirMedic and was recommended by someone here who has had their car done by him I believe.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #12 on: 22 April 2011, 21:45:36 »
If he used one of the new aircon machines they won't fill unless the system can sustain a vacuum for a set period indicating it's gas tight.
TuBy's new whipping boy.
« Reply #13 on: 22 April 2011, 21:55:48 »
I think you're on reasonable ground here SM.
The purpose in having the system re-gassed was to have it produce cold air when you wanted it.  If it doesn't then there's either something wrong with the system or the job hasn't been done correctly.
I think the temperature from the vents when the system is set to Lo should be around +4 to +5 degrees C  :question - it should be easy enough for him to check this.
I would imagine that there was some sort of guarantee for the work done?
SMD
  • London
    • :( nowt
« Reply #14 on: 22 April 2011, 23:08:14 »
It does produce cold air, just not very cold. What do I need to measure temp at the vents. I might just buy it myself.
