Author Topic: Alloys  (Read 2990 times)
rajveer.sandhu
Alloys
« on: 24 April 2011, 12:44:26 »
Hi,
Would the following Alloys and Tyres fit a 3.0v6 Omega: with variable nuts:
Front Wheel Size: 8.5J x 18" H2 (off set 18-35)
Rear Wheel Size: 10.0J x 18" H2 (off set 14-20)
Tyre Sizes: Front & Rear 235/50/R18
Raj
Re: Alloys
« Reply #1 on: 24 April 2011, 12:56:24 »
whats the pcd?
Re: Alloys
« Reply #2 on: 24 April 2011, 17:12:18 »
whats the pcd?
That's a good question Jimbob  :) ;)
Re: Alloys
« Reply #3 on: 24 April 2011, 17:19:28 »
whats the pcd?
I suspect incorrect for an Omega hence 'variable nut' (they'll be wobble bolts.) ;)
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Alloys
« Reply #4 on: 24 April 2011, 19:20:14 »
being 8.5j fronts i suspect they would rub with the base of the shocks? :(
rajveer.sandhu
Re: Alloys
« Reply #5 on: 25 April 2011, 16:52:35 »
Hi,
I am told the PCD is 5x120.
Would these fit with variable bolts?
MV6Matt
  • London
    • No car since 2022....
Re: Alloys
« Reply #6 on: 25 April 2011, 17:01:16 »
Hi,
I don't think so given that the Vx is 5x 110.
I think you can use wobbly bolts with +/- 2mm limits, so 120 makes it too big and not very safe
Are they Beemer wheels?
Matthew
« Last Edit: 25 April 2011, 17:02:06 by MV6Matt »
(thanks Ian)
MV6Matt
  • London
Re: Alloys
« Reply #7 on: 25 April 2011, 17:03:17 »
Tyre size would need to be 235/45/18 IIRC
Matthew
(thanks Ian)
jordan681
  • Sc unthorpe, North Lincs
    • Irmscher 3.0 MV6
Re: Alloys
« Reply #8 on: 25 April 2011, 17:08:11 »
for the fronts you can have either 225 - 245 40/45 18 and for the rear you caqn have anything up to 285's without having any rubbing issues.
I have 8.5 x 18 on the front and 10.5 x 18 on the rears, and the tyre sizes I went for were 225/40/18 on the front and 265/35/18 on the rear
Always looking for a bargin..  PM me if u have any uprated Miggy parts...
rajveer.sandhu
Re: Alloys
« Reply #9 on: 25 April 2011, 17:08:58 »
Hi, yes they came off a BMW 3 series.
Re: Alloys
« Reply #10 on: 25 April 2011, 17:19:59 »
I think that PCD is too large to safely fit on the omega
Re: Alloys
« Reply #11 on: 25 April 2011, 17:57:32 »
BMW wheels will not fit straight on, wrong bolt pattern. Don't know if there's an adapter spacer available...?
Re: Alloys
« Reply #12 on: 25 April 2011, 18:52:30 »
Blimey, properly tyred as per GM's recommendations, Omega's understeer like a pregnant dog at speed. That must be a handful in the bends ;D
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Re: Alloys
« Reply #13 on: 25 April 2011, 21:28:46 »
Have you got hubcentric spacers or are you not running much -camber/
Re: Alloys
« Reply #14 on: 25 April 2011, 21:33:57 »
Personally, I wouldn't fit wobble bolts at all... I don't trust them where wheels are concerned ::) ::)
