Author Topic: Stalling weirdness?  (Read 2440 times)
Debs.
Stalling weirdness?
« on: 28 April 2011, 13:20:07 »
Twice recently my 2.5 V6 has stalled (multiple times) when selecting drive or reverse (when hot)....and has had one episode of not wanting to fire (also when hot), but showing plenty of willingness to crank and which (most unusually) required heavy-accelerator to catch-it to run.....Once running she drove well.  :-?
I have cleaned the idle vale in solvent and checked for intake air-leaks, she has a fully charged battery and there`s no EML showing. :-/
What should I look to next?......Clippy-tricky?
Re: Stalling weirdness?
« Reply #1 on: 28 April 2011, 13:24:07 »
deffo....and expect the old 19 I reckon, crank sensor  :y
Debs.
« Reply #2 on: 28 April 2011, 13:30:18 »
Wilco and will report back :y!
« Reply #3 on: 28 April 2011, 18:06:36 »
Yep sounds like dodgy crank sensor  :(
Debs.
« Reply #4 on: 28 April 2011, 18:23:15 »
Feeling a bit nervous; I`ve not done the paperclip test before..... :-[
I`ve read the appropriate maint. guide; but don`t want to short anything out! :-/
« Reply #5 on: 28 April 2011, 18:25:22 »
Go for it Debs :y :y :y
« Reply #6 on: 28 April 2011, 18:27:46 »
Or alternatively.....are you passing here soon?
Ill happily plug in for you  :y
MutantCav
  • Gainsborough
« Reply #7 on: 28 April 2011, 19:22:34 »
Pin 4 and 6...pin 1 being top right 2 the one under it and so on :y
« Last Edit: 28 April 2011, 19:22:59 by ShieldOfSteel »
« Reply #8 on: 28 April 2011, 19:46:54 »
Subtle Jim, subtle. ::) :D ;D ;D
« Reply #9 on: 28 April 2011, 20:08:30 »
OI! Ill have you know im not offering to do anything for Debs that I havent done for her before
Debs.
« Reply #10 on: 28 April 2011, 21:44:26 »
 :y I was initially curious and then most satisfied........Jimbob knows exactly where to plug-in his equipment! ;)
 ::)......:P......;D
Debs.
« Reply #11 on: 28 April 2011, 21:46:54 »
 :yThanks very much, will give it a go tomorrow and video the resultant for review.:)
Debs.
« Reply #12 on: 28 April 2011, 21:49:25 »
 :y Thanks very much, James; I`ll have a go with the clip first and see if I can decipher the blinkin`light! :)
« Reply #13 on: 28 April 2011, 21:55:25 »
No worries, sure we can get together here or there if not  :y
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
« Reply #14 on: 28 April 2011, 22:11:03 »
 ::)......:P......;D
I'm feeling all left out! :'(
Been there, fallen over it!
