Author Topic: brake pad warning  (Read 1575 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
brake pad warning
« on: 06 May 2011, 19:54:18 »
brakes were checked out after a brake pad warning appearred and deemed to be ok, yet warning is still on. complete new, discs, pads, shoes rear 4 mths ago. front pads have been on 18 mths but are hardly worn, could it be a sensor,? :-/
Re: brake pad warning
« Reply #1 on: 06 May 2011, 19:57:35 »
Could be - try unplugging one at a time and shorting out pins in socket to check sensors.
raywilb
    • Citroen C4 Cactus
« Reply #2 on: 06 May 2011, 20:09:57 »
afterthought , i replaced the rear springs not so long ago & i wonder if i over stretched a wire.  :-/ .
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #3 on: 06 May 2011, 20:14:33 »
No pad sensors on the rear, just two on the front of yours Ray.
TuBy's new whipping boy.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #4 on: 06 May 2011, 22:45:01 »
more than likely a duff or broken sensor  :y
do as suggested and unplug each sensor in turn and short out the pins you will then know whether it is just one sensor or both  :y
« Reply #5 on: 06 May 2011, 22:48:27 »
you get a pretty good idea if it's goosed just by looking at it.  ;)
