Author Topic: 02 saloon back shocks same as 02 Estate back shock  (Read 1469 times)
OmegaBreaker11
  • Mayo, Ireland
« on: 06 May 2011, 17:59:11 »
Well
Im just wondering are the shocks and springs in a estate omega the same as a saloon omega (01 - 03 model)
Olympia5776
  • Ireland
Re: 02 saloon back shocks same as 02 Estate back shock
« Reply #1 on: 06 May 2011, 18:01:37 »
Shocks are definatly longer as are the springs I believe.
« Reply #2 on: 06 May 2011, 18:04:23 »
different length, and different fixing at the bottom end.
OmegaBreaker11
  • Mayo, Ireland
« Reply #3 on: 06 May 2011, 18:08:09 »
Rite thanks for that.....
The front ones would be the same would they....
« Reply #4 on: 06 May 2011, 18:15:09 »
Yes,
MV6 are different to the rest of the range and drop and stiffen the car slightly.
Recommended are genuine GM, or Bilstein B4's
« Last Edit: 06 May 2011, 18:15:28 by jimbob »
OmegaBreaker11
  • Mayo, Ireland
« Reply #5 on: 06 May 2011, 18:49:51 »
thanks for that info jimbob
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #6 on: 07 May 2011, 14:12:07 »
Yes,
And the genuine GM ones are BOGE, which is owned by Sachs nowadays  :y You can get BOGE ones with all the same stamps as originals  for a lot less money than the same parts from the dealers, at least that's the situation in Finland  :y
« Reply #7 on: 07 May 2011, 14:23:03 »
They are good value on the UK Tradeclub
under £50 each iirc
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #8 on: 07 May 2011, 19:58:58 »
yes they are longer as  i just changed mine and was sent the saloon springs and they make a hell of a noise over pot holes as they top out >:( an expensive lesson learned just ordered a new set of b4's for the back for €120
Warning: Dates in Calendar are closer than they appear.
