Author Topic: Cruise control ?  (Read 1748 times)
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
Cruise control ?
« on: 07 May 2011, 22:50:26 »
Will my facelift 2.0 16v year 2000 have cruise fitted and only needs a new stalk to operate this ? i hear some models will have this  :o :o :o
sam
Re: Cruise control ?
« Reply #1 on: 07 May 2011, 22:54:28 »
If it`s a 2.0ltr CD nope. You`ll need cruise stalk, actuator with cable, bracket on throttle body (rare only fitted to 2.0 CDX) possibly 4-pin brake switch (if not already fitted, doubtfull due to MY) plus a chat with TechII :-/
« Last Edit: 08 May 2011, 09:54:25 by RobG »
samrey4u
  • norwich
« Reply #2 on: 07 May 2011, 22:56:58 »
ITS A GLS  :o SO THATS A NO I TAKE IT
sam
« Reply #3 on: 07 May 2011, 23:01:34 »
You`ll need to find a 2.0ltr CDX being broken, doesn`t need to be facelift but must be 2.0ltr CDX
« Last Edit: 07 May 2011, 23:02:27 by RobG »
samrey4u
  • norwich
« Reply #4 on: 07 May 2011, 23:04:02 »
Thanks rob , great advice and noted will do that :y
sam
serek
  • huntingdon
    • 3.2 mv6
« Reply #5 on: 07 May 2011, 23:26:15 »
I fit criuse control kit to MY2000 GLS
and dont need throttle bracket or tech II
« Reply #6 on: 07 May 2011, 23:32:29 »
What did you use to hold the cruise cable on the throttle body :question
BOONY
  • sheffield
« Reply #8 on: 08 May 2011, 03:35:09 »
my 98 mini facelift 2.0l bracket with cruse holder but needed pedal switch no need for tech 2
my 96 prefacelift 2.0l was same as i remember
« Last Edit: 08 May 2011, 03:36:27 by JBOON »
« Reply #9 on: 08 May 2011, 11:28:44 »
Tech2 not reqd
M Kerr
  • Birmingham
    • 2.5 GLS Omega, X Type
« Reply #10 on: 09 May 2011, 10:18:58 »
Can I fit cruise to my 98, 2.5 mini-facelift?
« Reply #11 on: 09 May 2011, 10:21:30 »
almost certainly,
check you have the connector out the way on the suspension turret behind water bottle.
then get cruise actuator & cable, stalk, and brake switch (and clutch switch if manual) and away you go.
Guides on how to in the maint section.  :y
M Kerr
  • Birmingham
« Reply #12 on: 09 May 2011, 10:30:34 »
Top man Jimbob! That should give my right foot a break.
Many thanks, :y
