Author Topic: vauxhall omega 2.6 v6 petrol 2003 82,000 miles  (Read 3181 times)
watto
« on: 15 May 2011, 17:41:02 »
hello,
my car will not start.
put jump leads on first two times and it started.
yesterday wouldnt start with jump leads. sprayed quick start down air inlet.
battery is ok,i have had it checked and there are no fault codes.today it will not start again
had a problem over winter with immobiliser sounding and i bought a new battery.
any ideas [smiley=cry.gif]
« Last Edit: 15 May 2011, 17:42:36 by cwattam »
Re: vauxhall omega 2.6 v6 petrol 2003 82,000 miles
« Reply #1 on: 15 May 2011, 17:45:25 »
Do pedal trick for codes - bet its your crank sensor  ;)
watto
« Reply #2 on: 15 May 2011, 18:00:25 »
PEDAL TEST.
10   03   03   05
WHAT DOES THIS MEAN?
« Reply #3 on: 15 May 2011, 18:02:50 »
PEDAL TEST.
10   03   03   05
0335 which means you need a new crank sensor
http://www.omegaowners.com/forum/YaBB.pl?num=1220619696
& no need to shout  ;) ;) ;) ;) ;D
« Last Edit: 15 May 2011, 18:04:34 by Andy_B »
watto
« Reply #4 on: 15 May 2011, 18:06:49 »
THANKS VERY MUCH.
ARE THEY EASY TO CHANGE?
ANY IDEA HOW MUCH THEY COST?
« Reply #5 on: 15 May 2011, 18:11:33 »
THANKS VERY MUCH.
It lives up near the oil filter & secured with just one Torx headed bolt.
An OE sensor from Vauxhall is around £50 on Trade Club (can't access TC site any more so can't be precise of give you part number)
lastly ............
[size=18]TURN YOUR CAP LOCKS OF & STOP SHOUTING!!!!![/size]  ::) ;)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #6 on: 15 May 2011, 18:18:41 »
I can. ;D
Search Results
Your search for Omega ('94-'03) 2.6i 24v - Y26SE , Crankshaft Sensors returned 2 results.
Omega ('94-'03)
Crankshaft Sensors
Application  Description  Part No.  Retail  Trade  Trade Club
2.6i 24v - Y26SE   90492006  £83.50  £75.15  £65.12
2.6i 24v - Y26SE   90540743  £55.00  £49.56  £42.63
All plus VAT of course.
« Last Edit: 15 May 2011, 18:19:42 by CaptainZok »
TuBy's new whipping boy.
« Reply #7 on: 15 May 2011, 18:25:46 »
I can. ;D
  :P :P :P
Search Results
Omega ('94-'03)
Crankshaft Sensors
Why the two part numbers?  :-? Any ideas  :-/ :-/
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #8 on: 15 May 2011, 18:45:39 »
Must be a mistake, they only listed one in last years book.
2.6/3.0/3.2 90540743
« Reply #9 on: 15 May 2011, 19:07:22 »
Tradeclub site has gone VERY confusing on part numbers, list multiples on many
suspect it is listing all Y26SE engines, not excluding non omegas
« Reply #10 on: 15 May 2011, 19:22:31 »
A triple negative?  :-?  ;D
does that mean other cars?  ;D ;D ;D
watto
« Reply #11 on: 15 May 2011, 20:47:33 »
are aftermarket brands okay.
seen a new crankshaft sensor on e-bay for £38.40
what do you think
CAPS LOCK OFF
« Reply #12 on: 15 May 2011, 20:49:39 »
Don't buy Ebay ones. Only get them from you Vauxhall dealer ;)
« Reply #13 on: 15 May 2011, 20:50:46 »
Many have tried cheaper ones, only to end up buying the genuine ones...  ...so I'd stick to dealer...
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #14 on: 15 May 2011, 21:00:15 »
Ebay ones
buy one if you want to change it for a genuine one in a month or so  :y
