Author Topic: New fault codes  (Read 1204 times)
venom
  • South Moreton, Oxfordshire
New fault codes
« on: 12 May 2011, 12:38:24 »
The wife came home to the management light came on, so have done the clip test and 4 codes came up.
1st 12 which I can't find
2nd 16 knock signal circuit 1
3rd 19 incorrect rpm signal
4th 135 telltale checklight voltage low
Does anyone think they are all separate faults or all connected  >:(
Ken
Re: New fault codes
« Reply #1 on: 12 May 2011, 12:57:54 »
12 is start of codes - so ignore.
135 just relates to the EML - its working so ignore.
16 - Knock sensor - check the wiring to this, often get chaffed in the aux belt - if so chop out and fix the wire.  Prob this thats put the EML on.
19 crank sensor - doesnt put the eml on, but does cause breakdowns, replace with a new genuine crank sensor asap.
Re: New fault codes
« Reply #2 on: 12 May 2011, 13:15:03 »
19 is a sign of impending crank sensor failure (poor signal).
16 is the drives side knock sensor.
For former, consider a new crank sensor in the not to distant future.
For the latter, has there been any work carried out recently, cam belt or alternator change etc?
venom
Re: New fault codes
« Reply #3 on: 12 May 2011, 13:29:54 »
Cheers lads, I'll have to pull out the crank sensor to see if it's a metal or plastic one.
I changed the cam cover gaskets a few weeks ago so will have a look at it  :y :y
Ken
Re: New fault codes
« Reply #4 on: 12 May 2011, 16:18:19 »
Easy (apparently!) to trap the wire when doing cam cover gaskets - seen that a few times now
venom
Re: New fault codes
« Reply #5 on: 16 May 2011, 07:19:00 »
Waiting for a new crank sensor, but have checked the wire on the knock sensor & all seems OK & no pinking so could it be showing up as the crank sensors playing up  :question
Ken
Re: New fault codes
« Reply #6 on: 16 May 2011, 08:17:48 »
I'd have said unlikely, but is possible I guess.
Wait and see  :y
Re: New fault codes
« Reply #7 on: 16 May 2011, 20:25:40 »
Fix the crank sensor first mate as this can throw up all sorts of odd codes as well as the 19  ;)
venom
Re: New fault codes
« Reply #8 on: 21 May 2011, 15:25:51 »
 :) :) :) Fitted a new crank sensor & the only codes coming up now is 12 & 135, so the knock sensor is fine  :y :y :y :y
Ken
Page created in 0.028 seconds with 16 queries.
