Author Topic: autobox fault  (Read 1359 times)
mr busa
  • birmingham
autobox fault
« on: 02 May 2011, 23:19:05 »
got a 2001 2.6 v6 .when in drive the revs over rev and then the gearbox go,s thud and mil lite cums on,when switchd off then on its ok,its worse when hot.mil code says autobox request service,also have oil in coolent,oil cooler or headgasket.it runs great no over heating or running problems................  :-? help
« Last Edit: 02 May 2011, 23:31:29 by rf600r »
Re: autobox fault
« Reply #1 on: 02 May 2011, 23:25:15 »
Welcome to OOF mate  :y
Oil in coolant on V6 - oil cooler breaked  :(
Please don't use "text talk" - makes posts difficult to read
HTH
mr busa
  • birmingham
Re: autobox fault
« Reply #2 on: 02 May 2011, 23:35:47 »
thats what i thort it mite be,can they ba bypastd ;D :y
Re: autobox fault
« Reply #3 on: 02 May 2011, 23:47:44 »
Easier to just fix what's fitted.  :y
mr busa
  • birmingham
Re: autobox fault
« Reply #4 on: 04 May 2011, 23:06:05 »
fitted new oil cooler today and cleaned out coolent system,av done 220 miles and no oil in coolent. :y fanx for the help jus got to sort gearbox then i,m happy.  :D :y
ScaniaV8
  • Luton, Bedfordshire
Re: autobox fault
« Reply #5 on: 05 May 2011, 16:41:37 »
I suggest you check ATF fluid levels in gearbox as a start. But I also suspect you might see a code 19 recorded and this will probably be related to the  Crankshaft sensor needing to be replaced. I had similar problems with my 2.5 V6 auto and full gearbox oil change and crankshaft sensor replacement cured the problem.  good luck with your fault finding.
MutantCav
  • Gainsborough
Re: autobox fault
« Reply #6 on: 22 May 2011, 23:30:09 »
I have a decent AR35 gearbox here for £50 including the torque converter if you are interested???
MutantCav
  • Gainsborough
Re: autobox fault
« Reply #7 on: 23 May 2011, 08:29:44 »
Ok mate, unfortunately Omegas arent worth a great deal in full working order...and like every car, a lot less when they are needing work doing :(
