Author Topic: ECU  (Read 1096 times)
smurfdjman
  • Inchinnan,Renfrew,Scotland
ECU
« on: 09 June 2011, 20:21:51 »
when you send your ecu away to get refurbed what is it they actually do ??? is it like a new program or what
Re: ECU
« Reply #1 on: 09 June 2011, 20:24:04 »
Which ECU ?? and why are you "sending it away" ... for repair or modification ??
smurfdjman
Re: ECU
« Reply #2 on: 09 June 2011, 20:27:15 »
abs/tc light on and the speedo doesnt work
Re: ECU
« Reply #3 on: 09 June 2011, 20:29:37 »
Ahhh the ABS ECU.
they repair a broken, tiny, Bond wire
Re: ECU
« Reply #4 on: 09 June 2011, 20:31:16 »
So thats the ABS ECU . ... they will dismantle it and "redo" the burned out/broken connections from the plug to the board. There is a photo on the forum somewhere of the damage that occurs.
It needs a "special" piece of equipment to "redo" these connections due to 1) the materials used 2) the damage that would be caused by direct heat.
BBA-Reman did mine a few years back .. £130 with a 2 year warranty and it was back in less than a week. I was very pleased with the job and the speed. :)
EDIT ...  lifted this from another post .. picture courtesy of Mark_DTM
Whole thread is here ...
http://www.omegaowners.com/forum/YaBB.pl?num=1265622074
HTH  :)
« Last Edit: 09 June 2011, 20:39:16 by entwood »
