Author Topic: outside temperature  (Read 1188 times)
hazpaker
  • deepest Norfolk
    • 2.2 petrol cd
outside temperature
« on: 10 June 2011, 12:35:54 »
If the outside temperature sensor is faulty and giving a incorrect reading will this have any adverse affect on the air-conditioning and the inside temperature selected.
Re: outside temperature
« Reply #1 on: 10 June 2011, 12:51:14 »
In a word... Yes ;) If it's Climate Control and not just basic Air Con
The Climate Panel uses the outside temperature to aid in selecting the temperature required from the vents inside :y
« Last Edit: 10 June 2011, 12:51:50 by Lazydocker »
« Reply #2 on: 10 June 2011, 13:03:16 »
wot he said, plus they are only about £6 new from the dealer, and 2 mins to swap, open bonnet, they sit about centrally on the bumper.
tango
  • brum
« Reply #3 on: 10 June 2011, 13:20:06 »
yes definitly
i had a problem with the wiring loom and the outside temp was never showing
this affected the climate control
hazpaker
  • deepest Norfolk
    • 2.2 petrol cd
« Reply #4 on: 10 June 2011, 15:18:52 »
This forum is the best thing since tinned  beer, you post a question /problem and buy the time you have had a  cuppa or a tin or two up pops the solution /answer, once again thanks people for your knowledge and for sharing it. :y :y :y
