Author Topic: cam sensor  (Read 1257 times)
henri
  • Vendee France near La Sable D'
cam sensor
« on: 09 June 2011, 20:19:11 »
. been reading extensively about cam and crankshaft sensor problems and the symptoms either can throw up,mainly because I had a failure that at first caused me to change crankshaft sensor.Problem went away for 2 weeks but did'nt cure it. So with EML light permanently on codes 0335 and 0340,twice  I ordered cam sensor from AndyC  ordered Mon,delivered Wed to my door here in Vendee in France 10 mins to fit Whoopee problem solved That,s what I call service  :D :D :D
 thanks Andy
Re: cam sensor
« Reply #1 on: 09 June 2011, 21:27:37 »
Well done Henri and another great job by AndyC. 8-) :y
Re: cam sensor
« Reply #2 on: 09 June 2011, 21:49:03 »
glad your finally sorted
Re: cam sensor
« Reply #3 on: 10 June 2011, 08:27:23 »
Although cam sensor failure is rare on the V6 Omega, a P0340 shouldn't be ignored :y
Re: cam sensor
« Reply #4 on: 10 June 2011, 08:51:11 »
A bit concerned here as I am yet to EVER see a cam sensor failure on a V6.
Were the wires damaged in any way?
Is the cambelt setup and timing all ok?
henri
Re: cam sensor
« Reply #5 on: 10 June 2011, 20:48:00 »
Never had a problem with motor since I bought it ie engine wise,Had the cam belts changed by welung666 xmas when I was in uk no probs,never missed a beat then late April classic symptoms started and over a period of a week came to a complete stop.had the c/shaft sensor changed ran for 2 weeks and then started getting difficult starting,cutting out when slowing down, missing and engine light permanently on
changed the c/shaft sensor thinking the garage had used a pattern part,no joy,but when I read the codes myself(pedal trick) got 0340 ordered cam sensor fitted it and I am now back to normal car running as sweet as a nut.
Original cam sensor has no breaks or twists etc but does feel quite hard ,will check it out to see if resistance is correct
