Pages: 1 [2] 3 4 5 6 7 8 9 ... 14   Go Down
Author Topic: 3.2 still a little unhappy  (Read 21930 times)
Re: 3.2 still a little unhappy
« Reply #15 on: 14 March 2011, 18:41:21 »
Smacks of a multiram issue - sure they are working. Any vac leaks?
    • 530D M Sport, 330i Coupe
« Reply #16 on: 14 March 2011, 18:44:54 »
8. Gearbox has been behaving a little oddly – holding it in gear for too long, and then changing into the next gear with a very small ‘thump’ – this is intermittent, not sure if related, as this is the first A-Road run I’ve done with her.
I did think that the seals on the inlet bridge, plenum O rings etc looked a bit past their best, but, there is no noticeable air leaks.
Fix the known problems first.....
« Reply #17 on: 14 March 2011, 21:11:40 »
Exactly my thoughts TB....
But, I've had the car revved - and they both work.
Can't find any vac leaks - and - you get a good 'hiss' if you pull off the rear multiram connection after it's been running - indicating the front tank is holding a good vac?
VXL - although the intake seals looked past their best, I don't think there is an air leak, else it'd idle quick, etc etc?
And ref the gearbox, I really don't think it's related, just a bit tired...
« Reply #18 on: 14 March 2011, 21:14:24 »
Has the Brake vacuum pipe to plenum rubbed on the Aircon pipe at all? My first one did that.
« Reply #19 on: 14 March 2011, 21:17:50 »
You mean the thick one that comes from the servo, to the passenger side of the plenum - 19mm hex connection?
I'll double check it.
You know this has got me thinking. Although there is a 'hiss' when you pull off a vacc pipe when it's been running - it's not a POWERFUL hiss, like some Omega's I've seen...  :-/
« Reply #20 on: 14 March 2011, 21:24:45 »
Yep, where the vac pipe passes the top corner of the plenum it runs parallel to the aircon pipe. Can rub through the vac pipe.
« Reply #21 on: 14 March 2011, 22:03:38 »
Have you checked that funny shaped "o-ring" .. the one with the bar across it .. that sits in the centre of the plenum ??? I seem to recall it being broken on my 2.5, so blocking the 2 tiny breather holes and causing a serious power loss ... I know it breaks very easily when old.....did you replace it when you did the breathers ??
« Reply #22 on: 14 March 2011, 22:57:36 »
Hi Nige - I haven't touched that one - not got around to doing the breathers yet  :y
« Reply #23 on: 15 March 2011, 09:28:08 »
Other thing to check is that the non-return valve in the reservoir is working - otherwise your vacuum will disappear on full throttle.
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #24 on: 15 March 2011, 10:47:25 »
has anyone thought of useing a vac gauge to check vac quality? I bought one several months ago and never got round to useing it because couldn't find any positive "vac should be" info
« Reply #25 on: 15 March 2011, 11:06:26 »
Yes, I often do. If the vac is a little low it's a good indication of a leak in the system and watching the post-reservoir vacuum decay after stopping the engine (it shouldn't) can also give clues to what's going on with the non return valve and / or leaks.
EDIT: to answer the "what it should be", at idle with a warm engine I would say about 18-20"Hg / 30kPa absolute (70kPa / 0.7Bar  of vacuum below atmospheric).
« Last Edit: 15 March 2011, 11:24:45 by Kevin_Wood »
« Reply #26 on: 15 March 2011, 15:10:10 »
Just an update.
I tried plugging the line from the front vacc tank outlet, directly into a spare multiram, with the engine running.
I turned off the engine, and the ram stayed open, and didn't slowly return to it's original state, so it would appear it's holding a good vac?
I've also tried
- pulling off the feed line into the vacc tank after idle - no hiss. then pull off the outlet line - a good hiss - this indicates the return valve is OK, I guess?
I've also done a thorough inspection of vac pipes, removing them one by one - no damage or leaks evident  :-/
« Reply #27 on: 15 March 2011, 18:45:56 »
took her out for a run on a quiet road tonight
at 20mph - floor it - there is a good kick of power around 4000rpm, but - even in sport mode, it changes gear just under 5800 rpm - this can't be right???  :'(
« Reply #28 on: 15 March 2011, 19:26:34 »
Grow longer legs, or move seat forward :P ;D
hotel21
  • The Kingdom of Fife
« Reply #29 on: 15 March 2011, 19:30:49 »
Don't want to sound condescending but you are using the full length of travel of the accelerator pedal, as TB suggests, including into the kickdown switch??   ;)   :y
Pages: 1 [2] 3 4 5 6 7 8 9 ... 14   Go Up
Page created in 0.037 seconds with 16 queries.
