Pages: 1 2 3 [4] 5 6 7 8 9 10 11 ... 14   Go Down
Author Topic: 3.2 still a little unhappy  (Read 21970 times)
Boatboy
  • St Albans
Re: 3.2 still a little unhappy
« Reply #45 on: 15 March 2011, 20:43:20 »
Wild card maybe, but have you done anything different re fuel?
ie changed brand or RON.
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
« Reply #46 on: 15 March 2011, 22:16:42 »
I saw a 3.2 recently performing like a 1.0 Micra. ;D Intake ducting that feeds the bottom of the air box was sucking in on itself and starving it of air.
Can't see much wrong with the live data. Have the plugs been changed ?
What about fuel filter? :-/
« Reply #47 on: 15 March 2011, 23:46:23 »
Nothing changed at all. Just the thermostat and cambelt kit.
Was a rocket before - is now a snail by comparison  :'(
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #48 on: 16 March 2011, 00:30:20 »
Fuel filter, try changing it just to eliminate it from the probables, fuel injectors, could they be contaminated and partly blocked, you may have dragged some crud up from the tank.
Are you certain that you dont have an o ring dodgy. top end?
Jaguar XJ6
« Reply #49 on: 16 March 2011, 00:35:42 »
If it was OK before the work was carried out, that would suggest a very careful recheck of cam timing might be needed. :-/
« Reply #50 on: 16 March 2011, 12:12:27 »
This initially happened after JUST a stat change, so cam timing wasn't in the equation.
Cam timing is absolutely spot on, set up with the correct kit and all torqued to spec.
« Reply #51 on: 16 March 2011, 12:17:37 »
How cold was it running? If it was running too cool, would it not be over-fuelling, giving a slightly improved ooomph?  :-/
Can't see how else a stat change would affect performance  :-/
« Reply #52 on: 16 March 2011, 12:29:01 »
Wasn't running that cool, stat was tired, but not knackered... only noticed it overcooling a tad on a run...
ffcgary1
  • Mitcham,Surrey.
« Reply #53 on: 16 March 2011, 12:37:31 »
It seems to me the MAF is now the only thing left to check/swop out, 3.2's are known for being hard on MAF'S. This would affect performance.
Jaguar XJ6
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #54 on: 16 March 2011, 13:15:04 »
Fully sympathise with you on this as what you describe is exactly what I posted way back in July 2010 regarding my 3.2.
I only removed the plenum to change the cam cover seals and ventilator box and when I put it back together the engine power was flat. Like yours, I can visually see both multi-rams pulling under vacuum when someone revs the engine. I removed the plenum again, checked everything and it is still the same.
Interesting comment about the gearbox. When mine was running like a missile it would kick down if you floored the pedal at about 80mph in sport mode but since the plenum removal it sometimes just builds up speed rather than the awesome pull on kickdown that it used to have before I touched it. We both know that this is not a deterioration of something over time.
As you say, it went like a rocket before the plenum came off and is now flat which is exactly what happened to mine.
If you find the cause further down the line would you be kind enough to PM me of your findings. My hands are blistered and burnt from pulling vac pipes off the hot engine after your post triggered off my curiousity again.
Regards
Alan
« Reply #55 on: 16 March 2011, 13:24:57 »
So .. do neither of your cars kick down at all, and both change up early?
That would definitely point me toward the throttle position sensor or perhaps the throttle actuator (which presumably has a check-sensor built in).. dickey connection there, perhaps, after removing the plenum?
YZ250
« Reply #56 on: 16 March 2011, 13:39:23 »
Mine does kickdown but not at the higher speeds that it used to. This problem seems too similar to not be related. :-/
As plenum and vac pipes were the only things touched it's got to be linked to that surely but I just can't see anything wrong. No codes present on mine. As James said, they run fine when driven normal.  :-/
I do not have the knowledge as far as live data goes but the end result is that we both had cars that flew, we removed the plenum and now we both have cars that are not as they should be. As said, it's not a deterioration of something. They were fine until the plenum came off. Mines been hooked up to my mates snap-on modus and shows nothing wrong so I am now depending on James. :y
No pressure mate. ;D ;D
Regards
Alan
« Last Edit: 16 March 2011, 14:09:14 by Alan-Hearn »
« Reply #57 on: 16 March 2011, 20:31:18 »
So... The plenum has been off. I'd be checking and rechecking the o-rings... All of them. And the breathers :y
YZ250
« Reply #58 on: 16 March 2011, 21:29:19 »
Good point. Do these need re-setting/ re-calibrating after throttle body plug disconnection or is it not affected?  :-/  I assumed as nothing had changed it would be OK. Just thinking out loud as they are both 3.2 DBW.
I agree it's plenum or vac related.  :y
JamesV6CDX,
Apologies for butting in on your post.
I don't want to tread on your toes by answering on your thread so I'll take a back seat now. It does seem that our problems are connected. I'll continue to watch with interest.  :y
Regards
Alan
« Last Edit: 16 March 2011, 22:40:28 by Alan-Hearn »
unlucky mark mv6
  • tipton,west mids
« Reply #59 on: 16 March 2011, 21:43:43 »
If its any help james,the fuel filter was changed some time last year,along with the plugs,and new dispack on drivers side. :y
Pages: 1 2 3 [4] 5 6 7 8 9 10 11 ... 14   Go Up
