Author Topic: EGR  (Read 1072 times)
Roger777
  • Tyne and Wear
EGR
« on: 11 June 2011, 14:05:36 »
Please, 4 ? 99 2lt where is the erg
what is the cost of new
can i blank it off
will it matter  :-?
Abiton
Re: EGR
« Reply #1 on: 11 June 2011, 16:06:22 »
Right at the back of the head, next to the DIS.
This a view as if you were looking at the back of the engine:
Silly money for a new one (£100+).  Usually just require a bit of an internal clean/decoke if sticking.
 You can blank it off without noticing any difference, just insert a metal plate of suitable size between the base of the EGR and the alloy casting it sits on (fairly airtightly).
If you remove it completely after blanking, the ECU will throw a code and put the EML on I think, so just leave it on top of your blank if cleaning it doesn't help.
Roger777
  • Tyne and Wear
Re: EGR
« Reply #2 on: 11 June 2011, 17:01:58 »
Thanks I will try clean it :)
