Author Topic: Automatic transmission - plastic ring  (Read 1395 times)
Peti
  • 1994, V6, 2,5 l, aircon
« on: 20 June 2011, 09:34:56 »
There's this plastic ring I found broken into 3 pieces when removing the SMALLER sump of the automatic transmission :
Plastic ring :
Suppose I can buy a new one.
But then I just can't imagine WHERE does it come from.
Can anyone show me on this picture ?
Sump:
Re: Automatic transmission - plastic ring
« Reply #1 on: 20 June 2011, 10:07:50 »
thats the dreaded thrust washer - there is a post on replacing it in the maintenance section. check the index in my sig.  :y
you will need new gaskets, fluid and an uprated brass thrust washer.
box bits can be obtained from JPAT, fluid from opie oils.
« Last Edit: 20 June 2011, 10:09:44 by jimbob »
Peti
« Reply #2 on: 20 June 2011, 11:38:44 »
Well, this looks everything but easy!
I thought I just buy a new one and click it to its place using 2 fingers  :)
« Reply #3 on: 20 June 2011, 11:46:41 »
its not hard.....once the box is off the car.
« Reply #4 on: 20 June 2011, 11:56:17 »
There's a guy round here will do that sort of job for £200 plus parts.
Ime you need a local garage with auto box experience. Not an auto box only specialist as such, they tend to take the pesh a little.
It can be done on the drive though, apparently.  :-/
Peti
« Reply #5 on: 20 June 2011, 12:17:20 »
Lately,when leaving the garage(i.e. when everything was cold) , it took the transmission unit quite a few meters to change from gear 1 to gear 2.
Do you think that plastic ring is to blame for that ?
Do I take a big risk if I do NOT replace it for a while ?
« Reply #6 on: 20 June 2011, 13:15:41 »
Standard operation, it does that when cold to get the engine to warm up a little quicker.
Peti
« Reply #7 on: 20 June 2011, 13:23:52 »
That sounds fine, but do you think it is a big risk NOT to replace that plastic ring immediately ?
