Author Topic: fault code 0560  (Read 1124 times)
vomega51
  • east london
fault code 0560
« on: 20 June 2011, 18:55:50 »
hi, whilst driving earlier my dash warning lights decided to all come on and then go out, the engine was lumpy so limped to a friends who connected a fault reader and 0560 came up saying system voltage malfunction, can anyone comfirm that this is a faulty alternator please, also when i carried out a pedal test the spanner is flashing continuously, can anyone help me out, any replies will be appreciated, thanks, kevin
Re: fault code 0560
« Reply #1 on: 20 June 2011, 19:25:26 »
What is the battery voltage at:
Engine off
Idle
2.5k rpm
vomega51
  • east london
Re: fault code 0560
« Reply #2 on: 20 June 2011, 19:31:01 »
hi, thanks for taking the time to reply, i dont have means of testing the voltage at the moment but i have changed battery and deleted the code code but it has come back and is still showing same code and now the battery light is staying on, thanks, kevin
Re: fault code 0560
« Reply #3 on: 20 June 2011, 19:35:07 »
Sorry, measuring that is the next step.
You run a risk of knackering your new battery if it is overcharging....
vomega51
  • east london
Re: fault code 0560
« Reply #4 on: 20 June 2011, 19:41:02 »
thanks for your advice, i will check voltage tommorrow and get back to you if thats ok, thanks, kevin
