Author Topic: Fault codes 64 and 92 omega95 2,5td  (Read 1084 times)
kenneth71
  • norway
« on: 25 June 2011, 10:27:51 »
Hi all, i have these fault codes om my omega and dont know where to start to fix them. Have been browsing this forum and also tried to search, but no luck.I read in a post that 64 combined with 34 means basically change fuelpump but is this also the case when i just have the 64 code??and for the 92,Cruise Control Device Circuit Open Or Voltage High i dont understand since i dont have cruise control...any hints to where to start???
Re: Fault codes 64 and 92 omega95 2,5td
« Reply #1 on: 25 June 2011, 10:36:55 »
Thats BMW for you....
The code is because you dont have a cruise control stalk fitted!
its enabled in the ECU, to get rid of the code, buy and fit a cruise control stalk (TD specific not petrol one, very different)
kenneth71
  • norway
« Reply #2 on: 25 June 2011, 21:59:54 »
Thx, will do that.
Anyone have an idea about the fault code 64???must be somthing i can do to fix it, the car acts like the fuel cuts off and the enginelight blinks when i change gears but only when the engine hasnt reached normal running temperature, when driven for a while and engine is normally hot it works fine....any idea????
hoofing it
« Reply #3 on: 26 June 2011, 06:31:44 »
Thx, will do that.
You can try Forte diesel treatment.
First get a new fuel filter and fill it with the treatment(full bottle) then fit the filter to the car start the engine and hold the revs about 1000rpm.
This cleans out the pump(sensors in the pump) but you may need to do this a couple of times also add a bottle of treatment to half a tank off fuel :y
Omegatoy
  • UK
« Reply #4 on: 26 June 2011, 08:33:18 »
Thx, will do that.
Good advice!! its possibly the only easy fix for this problem :y
kenneth71
  • norway
« Reply #5 on: 26 June 2011, 10:22:38 »
Thx for the advice, i`ll try that.....
